I am a software engineer in 3d graphics by day so please bear with any obvious mistakes. I am looking for a project that I can use my software knowledge with in hardware and am thinking of creating a frame buffer and lcd to display it. I have looked around and think I can accomplish it with this fpga:
https://xess.com/prods/prod048.php
And this LCD:
http://www.sparkfun.com/products/8335
I think they have:
480 x 272 = 130560 pixels on the screen
130560 x 24-bit = 3133440 bits for the frame buffer
67108864 bits of sdram to store the frame buffer
So I think I'm ok there. And I think can run the fpga at 9 MHz (that the lcd needs) because it has "digital clock managers" to change from 12 MHz. Which I believe I will need 3133440 Hz to write the entire buffer. I think I can also get input from the usb for writing the pixel colours to the buffer.
The fpga can output either 5, 3.3 or 1.2 v for logic, but the lcd requires 2.5v however in the manual it says "0 ~ +4.5"... So could I use the fpga logic voltage directly?
I am learning as I am doing this so I am going to make a lot of mistakes, but is there anything obvious I am missing or am I good to get our my breadboard and have some fun?
Thank-you
