Tell me more ×
I'm getting a streetlight, most likely with a HPS bulb (high-pressure sodium). I'll probably hook up some sort of sensor to turn it on only when someone is actually parking lot.
Why do some streetlights seem to take a long time to turn on? Is there anything that can be done to get parking lot lights to turn on quicker?
Why do some companies say you must let the bulb cool down for a minute or so after you turn it off, before you can turn it back on? Is that a limitation of the bulb itself, or the control ballast, or what?
Can "dimmable HPS" systems reach full brightness from a nearly-off dim state quicker than traditional on/off HPS systems?
The only dimmable HPS systems I've seen so far can dim down to a minimum of 1/2, which visually seems only slightly less bright than full on. Is there some reason HPS can't dim down to 1/10 or 1/100 like other lighting technologies? (Am I just not looking in the right place for dimmable HPS systems?)
How do you dim a streetlight bulb -- how is the voltage/waveform applied to the bulb different at dim than at full power?
Are there any reasonable alternatives to HPS bulbs? If Haitz's law continues, then someday LEDs will cost less -- but the current LED lamps that last 10 times as long, but cost 100 times as much to get the same brightness, don't seem reasonable in 2011.
(Edit: dropped protocol question as suggested by Jay Kominek - it's at motion detected protocol )
share|improve this question
This is too many questions to be reasonable. Do you expect every answer to address every question here? – Kortuk Jan 12 '12 at 20:17
Question list is fine. Nobody has to answer them all but together they make a nice HPS FAQ. An HPS expert (which I'm not) could answer about all of them "off the cuff". Ask me a list of questions about LED street lights and see how we go ...:-) – Russell McMahon Jan 12 '12 at 21:13
Not a fan of question lists. – tyblu Jan 13 '12 at 0:07
I agree with Kortuk and tyblu: ask one question at a time. – stevenvh Jan 13 '12 at 5:25
Dump the protocol question, down to the bottom, and then it reads sort of as "how do i control high pressure sodium bulbs?" which seems like a decent enough question. – Jay Kominek Jan 13 '12 at 6:14
show 1 more comment
up vote 8 down vote accepted
Questions
  • indented like this.
Answers on margin.
  • I'm getting a streetlight, most likely with a HPS bulb (high-pressure sodium). I'll probably hook up some sort of sensor to turn it on only when someone is actually parking lot.
HPS is not a good choice for rapid turn on use. You'd probably be better served by a more standard bulb such as a Halogen, or something exotic like HID, or 'solid state' like LED.
  • Why do some streetlights seem to take a long time to turn on? Is there anything that can be done to get parking lot lights to turn on quicker?
Long turn on is caused by the technology used. Usually this involves the vaporisation of a metal and building up temperature and pressure. There is nothing sensible that you can do except change technologies. If you have a military-type budget you may find a faster way but for mere mortals, buying what is provided is typically the only choice.
  • Why do some companies say you must let the bulb cool down for a minute or so after you turn it off, before you can turn it back on? Is that a limitation of the bulb itself, or the control ballast, or what?
Most bulbs that use a gas arc or ionisation of a gas require a starting voltage which is significantly higher than the running voltage. When the tube is hot the starting voltage can be higher again - perhaps by a factor of 10 in some cases. While starters can usually be made to "strike" the tubes in such cases. Since this adds extra cost it is usually not justified in applications where only a few people occasionally need to restart lights.
In specialist cases where failure to restart is unnacceptable, the effort and expense is taken to provide the extra voltage. An excellent example is HID lighting for cars. An HID light has a very small sized arc and white light. The small arc size allows excellent optical handling for beam forming (as in cars or projectors). The white light is attractive for various reasons. When cold an HID tube requires many hundreds of Volts to strike and when hot it requires many kV - perhaps 5-10 kV. HID controller makers for lamps used for fixed lighting may decide to not provide the HV restrike capability - it adds cost and dealing with HV is a reliability issue. But in a car you must be able to turn the headlights back on instantly at any time. So all automotive HID controllers have hot strike capability.
  • Can "dimmable HPS" systems reach full brightness from a nearly-off dim state quicker than traditional on/off HPS systems?
I don't know, but, almost certainly yes. Once an ionised start is obtained, if it can be stably maintained at low power, you'd expect increasing the temperature and pressure to higher levels to be much quicker than bringing them up from cold. Manufacturers' data sheets should comment on this.
  • The only dimmable HPS systems I've seen so far can dim down to a minimum of 1/2, which visually seems only slightly less bright than full on. Is there some reason HPS can't dim down to 1/10 or 1/100 like other lighting technologies? (Am I just not looking in the right place for dimmable HPS systems?)
Again, an informed guess: The minimum energy required for stable ionisation is still fairly high and if you try to reduce the brightness below that, the light simply turns off. Hence my caveat above, "if [stable ionisation] can be stably maintained at lower power". I'd expect better than 2:1 to be possible but probably not vastly better.
  • How do you dim a streetlight bulb -- how is the voltage/waveform applied to the bulb different at dim than at full power?
That very much depends on technology and on regulatory requirements. Where a bulb uses advanced technology and is sold as "dimmable" the manufacturer will provide very specific instructions. Technologies that accept linear current drive variation (e.g. incandescent, halogen and some LED systems) will allow very simple waveform control - either TRIAC leading edge waveform shaping or leading and falling edge or a power factor corrected reduced envelope. Other technolies may get a special waveform and conditions from a special controller and may be considered a "black box" from the entrance to the controller onwards. For example, some LED systems use 2 or 3 stage hill and valley circuits to fill the "valley space" around mains zero crossing points with energy taken from the cycle peaks. and they THEN apply a buck converter. The input to the dimmer is the start of the special magic and you then do not lightly separate the LED 'bulb' and controller. An HID controller will almost invariably be very close to its bulb. (People don't like reticulating 10 kV).
  • Is there a standard protocol for sensors to tell parking lot lights that motion has been detected, so the lights need to turn on?
I dont know. But no. This is a simple task and there are liable to be various ways of implementing a fairly straight forward choice. In most cases a simple timeout will do. Complexities such as usage patterns, time of night, etc. can easily be added if a microcontroller is used in the system.
  • Are there any reasonable alternatives to HPS bulbs? If Haitz's law continues, then someday LEDs will cost less -- but the current LED lamps that last 10 times as long, but cost 100 times as much to get the same brightness, don't seem reasonable in 2011.
Yes. How much light do you want?.
There are many issues other than life and cost alone.
LEDs offer almost the best to the best energy use when running, instant turn on, instant restart, wide range dimming, low temperatures (low stress on other components), low maintenance and replacement costs, etc.
HID bulbs in the 30-200 Watt range are available for automotive use and would be trivially adaptable for street lights. No doubt they are also available for streetlights formally.
Halogen bulbs have lower efficiency but offer instant on, dimmability, instant restart and excellent CRI (colour rendition).
share|improve this answer
Excellent. Thank you very much. I am curious about the details of the "special magic", but you've already given me a better answer than I expected. – davidcary Jan 16 '12 at 20:50
LED's will drop to 25% of present wafer costs when then achieve long life and transparency on Silicon instead of the present Sapphire substrate. – user11355 Aug 9 '12 at 1:22
Many types of vapor lamps require that the internal gas be at a certain temperature for normal effective operation. When the gas is too cold, the lamps cannot effectively generate light, but must instead act in some fashion which will generate heat until the gas has reached the required temperature. Further, dimming the lamps too much might reduce the amount of waste heat they generate to the point that they could no longer remain hot enough to function.
If one were to add heaters to a lamp, one could accelerate the startup and also dim them to almost nothing without them cooling off too much and shutting down. Note, however, that reducing the power fed to the light generation circuitry would increase the amount of power needed by the heaters, so overall energy savings would not be as great as one might expect.
With regard to the "mandatory off time" of sodium lamps, when such lamps are at room temperature, much of the sodium exists as solid metal; when they are switched on, the sodium evaporates. The lamps are designed to ensure that when the sodium solidifies following shutdown it will do so at a place which will get hot when the lamp is next switched on. If the lamp were switched on and off erratically, some of the sodium may end up being deposited in areas which won't be heated effectively the next time the lamp is powered up. Even if such areas would in normal operation get hot enough to vaporize any sodium there, it would be possible for enough sodium to get deposited in such areas that the lamp could no longer start (and would thus not be able to heat itself enough to re-vaporize the sodium).
The dimming capability can be tricky down to 20% without flicker, The warm-up period is totally up to the bulb of 20 minutes.
After the 20 minute ignition warmup time you can dim it down to 20% without flicker if you know what you are doing. If you try before that, it might flicker due to dynamic changes in bulb impedance and thermal temp and state of sodium plasma.
One company advertises an Intelligent Power Management Module (IPM) in HK light fair with such technology using triac phase control with feedback on sodium lamp current which changes with temperature of the bulb.
Electronic HPS Dimmable Control Gear (IPM-Intelligence Power Management) enter image description here
This company supplies them various power levels 75~250W
BTW I know a few companies that make LED lamp standards that will have a payback period of 5 yrs and improve acuity of detecting pedestrians and road conditions company to HPS. Not all are equal. The best use no fans with space age vortex cooling and 99% silver epoxy.
discard
