Tell me more ×
Why is it that places like Newegg can sell consumer Bluetooth products for less than $10, but the only Bluetooth modules I can find on Mouser or Digikey cost close to $20?
I am looking for the cheapest way to support bidirectional communication via Bluetooth SPP. Does anyone know why these chips are so expensive?
share|improve this question
Nothing to do with electronic design. Question should be closed. – Leon Heller Jan 13 '12 at 10:37
closed as off topic by Brian Carlton, Nick Alexeev, Dave Tweed, Olin Lathrop, embedded.kyle Nov 9 '12 at 15:51
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
up vote 2 down vote accepted
In mass production a BT chip costs less than 75 cents. The problem is none of the vendors will work with you, you need to find a module maker who can support you. In MP you can reach to 5$ level with module including antenna etc. good luck.
The key vendors to look at are CSR and BRCM. We use a Taiwanese module maker with one of their solutions. APMComm is the vendor, there are tons of others just look around.
share|improve this answer
Thanks for the info. What's "MP"? – Zach Rattner Jan 13 '12 at 16:01
BRCM = Broadcom. – Brian Carlton Jan 13 '12 at 17:20
MP= Mass Production – Frank Jan 16 '12 at 3:11
We are currently having a similar problem. Here is what we discovered so far:
For small (e.g. prototyping) quantities eBay has quite a few modules available for as low as £5.
For production quantities there seem to be plenty of Asian vendors, it's just a matter of finding the right one. Check on places like Alibaba, as Frank mentions as low as $5 is possible with the right quantities.
