Do you know any tools which perform design rule checking for Gerber files of PCB and are suitable for using in batch mode on a remote server? Something similar to what BatchPCB or FreeDFM uses (I asked BatchPCB but they haven't answered yet.)
DRC is a rules-based software that requires maintenance to latest IEC design specs. These change annually, so don't expect too much from a free DRC checker unless you are doing old technology. ALso beware that the requirements of pick and place, reflow/wave solder, and hand solder change all the rules. You might be able to afford this: http://wssi.com/gerbtool/ |
I trust one of these suggestions is adequate for you. |
Well, with my little experience on PCB Design, I want to believe the PCB Design software could do a DRC test and you might not need get a separate software to do that. Moreover, designs vary and the PCB layout as well might vary, so I usually will set my rules based on what I am designing at the moment, and that is if its really needful anyway. You could check out the IPC standards on this regards. |
