Tell me more ×
I want to generate a high frequency (4.25 GHz) clock for a high frequency communication circuit. So, my question is:
What are the alternate ways of generating the high frequency clock and which would be the best way out?
Some pointers to components/ICs would also be of great help.
share|improve this question
Stability specs? – Russell McMahon Jan 25 '12 at 13:41
Is this homework / assignment? – Russell McMahon Jan 25 '12 at 14:00
More detail please. Is this homework. If so, tell us what is being asked of you and we will help you learn. – Russell McMahon Jan 25 '12 at 14:07
@RussellMcMahon: No, this is not homework. I am designing a high bandwidth (500 MHz) communication circuit around 4.25 GHz central frequency. I am not sure of stability specs. – Neel Mehta Jan 25 '12 at 14:14
1 Answer
up vote 3 down vote accepted
  • SAW
    Impatt Diode
    Gunn Diode
    Magnetron / Klystron / TWT
    Esaki diode (tunnel diode)
    fXo
    Fractional N synthesiser.
    More ...
For $US35.70/1 on stock you can gete 1 GHZ fxo modules from Digikey here for prices.
FXO-PC73 series. Up to 1.35 MHz. Multiply in various ways from there.
Datasheet here They say:
  • EXTREMELY Low Jitter
  • Low Cost
  • Frequency Resolution to six decimal places
  • Stabilities to ± 20 PPM
  • -20 to +70°C or -40 to +85°C operating temperatures
  • Serial ID with Comprehensive Traceability
For $5/1 you can buy synthesiser ICs that cover your range.
Typical example only
Pricing
Datasheet TI LMX2434
Gunn diode oscialltyors using cavities for fequency tuning and with varactors for tuning are a time honoured solution and may give you power levels that can be used directly.
intro
more intro - good
ZAX Gunn oscillators
Zax catalog - very pretty
Gunn XBan - well above your range useful
Ham Radio mag 1980 DIY 10 GHz - very relevant if DIYing here
MUCH more. More detail please. Is this homework. If so, tell us what is being asked of you and we will help you learn.
share|improve this answer
Does the integer-N PLL (which can go upto 64/5) allow locking into any multiples of the oscillator/crystal frequency? or is it just powers of 2 (e.g. 32/33, 64/65, etc)? – Neel Mehta Jan 26 '12 at 6:43
If I use a 50 MHz crystal and a PLL frequency synthesizer like ADF4108, can I generate a 4.25 GHz clock? – Neel Mehta Jan 26 '12 at 7:04
discard
