Why is it generally a bad idea to formulate node voltage equations for an op amp circuit at the op amps output? Does this idea only apply in the ideal op amp model?
I recall it has to do with the idealized zero output impedance of an op amp, and maybe I'm just not understanding the consequences of this, but why does this mess up the analysis? I would really like to get a better understanding of what I can and can't do when playing with different network layouts that utilize op amps. As of now when I write out a possible op amp configuration I am wary of my design because of this ambiguity in where the analysis starts to become wrong. A cascaded op amp design is even worse because I do not know where to even start.
I guess the greater question is:
What is unique about the op amps network topology and/or variable relations that may lead to inconsistent equations? That is, what do i need to look out for while forming equations pertaining to a given (ideal) op amp model?
EDIT: I realize this is a rather broad question, so I added an pic/example of a situation where the analysis leads to a contradiction.this is just the simplest case of what im talking about. In general I find eqns formed at an op amps output tend to lead me to wrong answers.
I have an introductory textbook for circuit analysis that specifically tells me not to formulate node equations at OP AMP output nodes but does not expand on why. I find it hard to gain confidence in working with op amp equations when a underlying contradiction might pop out of nowhere.
EDIT2: Basically, I have a voltage source in series with \$R_{in}\$ (a resistor immediately prior to the op amp) into an ideal op amps non-inverting input and the op amp forms a unity gain follower (output is connected to the inverting input of the op amp). Following this, there is a load resistor which is then in series with the negative terminal of the original voltage source. Here's the schematic:
The contraction comes from the fact that the input current to the non inverting input to the op amp is the same current that runs through the load resistor that follows the op amp. The ideal op amp input current is zero and yet the current through the load resistor is non-zero (this is a contradiction).
