Tell me more ×
I have a regulator such as in this setup to provide 1.2 Amps to a load that requires constant current:
R1 is set to 1 Ohm, which nicely brings the current within range (1.25A according to a small calculator below the image), but what I do not understand is that it speaks of a 1.25V reference. Does it output 1.25V only, or does it output the input voltage (minus) voltage drop (vdrop maybe 3V) and the 1.25V is just specific to ADJ?
Can I output voltage to, say, 2V as well as 1.2A constant current with just one LM350 device?
The datasheet for the LM350 I will be using is the following: http://www.ti.com/litv/pdf/snvs772a
share|improve this question
up vote 3 down vote accepted
In constant current mode, it will output whatever voltage is necessary to push (in your case) 1.2A through the load.
This will be limited by the supply voltage (minus a bit for the regulator drop) as obviously it can't output a higher voltage than goes in. So you can't expect it to put 1.2A through an e.g. \$ 1 M\Omega \$ resistor unless you have a supply of 1.2 Megavolts handy :-)
Foe example, if you have a 1 ohm resistor as the load, the voltage at the load will be:
1.2V (\$1.2V \div1 \Omega\$ = 1.2A)
If you have a 5 ohm resistor as the load, the voltage at the top of the load will be 6V (\$ 6V\div5\Omega\$ = 1.2A)
You can't set it up for constant current and constant voltage, as to keep one constant requires varying the other.
However, with a static load in constant current mode you can set it to drop 2V - e.g. \$2V\div 1.2A = 1.6666\Omega \$ resistor needed. So if you have a load of \$ 1.6666 \Omega \$ on the output of a constant current of 1.2A, the voltage will be 2V.
share|improve this answer
Hah! There are a lot of 5W+ 1.5-2.0 resistors at Digikey I could use. So maybe I can assume.. 5V input is required for the LM350 for this to work? 3 drop leaves 2V, I think I can get this on my own, not sure of what to calculate in my head at the moment though. Thank you. – Kenny Robinson Feb 10 '12 at 0:58
The input supply doesn't matter as long as it's high enough to allow for the minimum drop for regulation (stated in the datasheet, say at least a couple of volts for a standard reg) All you need is the right load resistor, which in this case is 1.6666 ohms and you will get a 2V drop (with 1.2A). The input voltage can be anything > 5V to whatever the max voltage is for the regulator. Obviously you need to account for power dissipation as Photon mentions - the higher the input voltage above the output voltage the more power dissipated by the regulator. – Oli Glaser Feb 10 '12 at 1:04
Thank you, I am very satisfied with my project planning now. – Kenny Robinson Feb 10 '12 at 1:06
It's a 1.25 V reference because the circuit will operate to keep the ADJ pin 1.25 V below the OUT pin. The OUT pin will be driven to whatever it takes (up to Vin - 3 or so) to force the ADJ pin to be 1.25 V below Vout.
To answer the question the way you phrased it in the title, you can't get the power supply circuit to force both a fixed current and fixed voltage at the same time. That wouldn't leave any freedom for the load to affect the circuit. For example, if you have a 1 Ohm load, you need 1 V across it to get 1 A. If you have a 2 Ohm load, you need 2 V across it to get 1 A. If the supply circuit tried to force both at the same time, you'd have a logical contradiction on your hands.
Note that to get 1 A output you will need to be sure to pick the right package type for your LM317 and also you will probably want to use an external heat sink (or a good thermal connection to your PCB) to avoid overheating the part.
Absolutely, I am trying to get a metal case that I can mount this on, however heat sinks are on my shopping list and a spare 'LM if one of my attempts fail. Thank you. – Kenny Robinson Feb 10 '12 at 1:07
discard
