I am building an energy harvesting sensor for building installation, and I have to choose between two panels:
Indoor, 5V, 47uA Isc @ 200 Lx
Outdoor, 6V, 15.9mA Isc @ 50 kLx (note the different light level rating)
Given that they have similar dimensions (negligible difference for the application), one would say that the indoor panel would be more efficient with narrow band light such as the one generated by a lamp.
The problem is that this last detail is not included in the technical data sheet, as it's not included the I-V curve, that can however be traced from measures or taken from models.
Now, the strange thing is that the outdoor panel has shown a better performance (in terms of power given at the MPP) under the same - indoor - light conditions; this test has been done in a working environment, that should be lighted at about 500 Lux; the lamps are probably fluorescent, and probably with a quite good "white" light. Also with shading (a hand above the panel) the outdoor one gives more power.
Now we decided to use the outdoor, but can you find a reason for that? And what would be (apart from price) the advantage in using the indoor panel?
