Tell me more ×
In the context of solar cells, some films such as aluminium oxide reduce recombination by "field effect passivation". I find this mentioned often, but can't find a definition or clear explanation of the mechanism anywhere.
It seems to be something to do with the concentration of negative charge at the surface, which leads to a layer just beneath the film with a high concentration of holes, but it's not clear to me how this leads to passivation.
share|improve this question
I thought this had something to do with combining with the free oxygen in the air over time as apposed to putting the full oxide layer down deliberately during manufacturing, but I could be quite wrong about this. Passivation is usually a coating of something inert, like a metal oxide (glass being silicon oxide). – Olin Lathrop Feb 25 '12 at 13:36
up vote 0 down vote accepted
I assume you're talking about thin-film crystalline silicon solar cells.
Surface passivation can be achieved in several ways:
  1. reducing the recombination at the interface (chemical passivation), and
  2. electrostatically shielding the charge carriers from the interface by an internal electric field (field-effect passivation), or
  3. a combination of both.
There has been good success in using plasma-assisted ALD to passivate c-Si using ultrathin films of \$Al_2 O_3\$. Surface passivation has become more important as c-Si wafer solar cells move towards lower substrate thicknesses and the surface-to-volume ratio increases.
The effect of field effect passivation is to decrease the surface recombination velocity. The fixed charges at the surface of the c-Si interact with the charge carriers in the c-Si bulk and induce a depletion or accumulation layer close to the c-Si surface. If the charge density is sufficiently large it can even create an inversion layer at the c-Si surface. A decreased surface recombination velocity means higher carrier lifetimes and thus higher efficiency cells.
share|improve this answer
This is only in Thin Film Solar Panels I suppose. I don't know the exact reason for the formation of the film, but i do know how one gets rid of this. 90% of the manufacturers recommend to negatively ground the thin film panels which allows the negative charge to move to the ground thus not allowing the film to be formed.
discard
