Tell me more ×
I want to start a new project and build a PC in an antique style radio. The back of it says "CAUTION RISK OF ELECTRIC SHOCK. DO NOT OPEN"
It's just a 120V 60Hz 8 watt radio, but this warning has me wondering how to discharge the thing safely. What part of the board does this warning pertain to? The transformer?
share|improve this question
As long as it's disconnected (it is, right?) you shouldn't worry about that. Nice idea anyway! – clabacchio Feb 25 '12 at 20:35
@clabacchio Well, there could still be charged capacitors in it, so I wouldn't say it's 100% safe. – exscape Feb 25 '12 at 20:49
@exscape ok, but....how long has it been off? – clabacchio Feb 25 '12 at 20:53
If it's been unplugged for at least a minute, it should be fine. – Olin Lathrop Feb 25 '12 at 21:03
@samoz: That doesn't necessarily work with old tube circuits. Without the cathodes getting hot there could be nothing draining the high voltage cap. – Olin Lathrop Feb 25 '12 at 23:22
show 1 more comment
1 Answer
up vote 4 down vote accepted
First, never, ever ever work on a tube radio while it's plugged in!
Assuming you just want to gut out the radio circuits and keep the case, if it has been unplugged for a year, it's probably safe.
There were two common reasons for such labels. First being, capacitors can hold lethal charges for hours to days after the circuit is powered off. The other is an abominable practice from the early 20th century of bonding the neutral wire of the power cord to the radio chassis, and counting on (1) a polarized plug, (2) correct domestic wiring, and (3) the insulating value of the case to protect the user.
If this radio is truly an antique, and you know no one has tried plugging it in recently, it should be safe enough.
share|improve this answer
discard
