Tell me more ×
I'm using a single board computer to talk on a phone line through two coils, one for the TX part, the other for the RX. The phone line is on another coil and then it's connected to a two-wire circuit that leads to an handset. As you know, the problem with this config is that if you build a full-duplex communication system with VoIP in the middle, you hear the echo from what you just transmitted on the network coming back See this connection scheme
Is there a circuit which is able to reduce or eliminate such echo? Right now I'm using a DSP to implement a simple subtractor (Rx=Rx-Tx), but maybe this common problem has been solved by clever analogue engineers back in the past.
Connection scheme with echo path in red
share|improve this question
@Kellenjb thank you! My specific question would be about a circuit which does that "automatically", exploiting the magnetic circuit or something like that. – Metiu Mar 1 '12 at 16:39
Yeah, I understand its not a duplicate, just close enough that I figured it was worth linking to. – Kellenjb Mar 1 '12 at 16:40
1 Answer
The analogue circuit is known as a "two-wire hybrid" and does exactly what you are doing with your DSP. Strictly speaking this is just sidetone elimination rather than echo cancellation which Kellenjb's link addresses. Below is a simple example (which is a discrete replacement for an obsolete Mitel part). This arrangement only works if the load impedance is precisely controlled - in this case 754\$\Omega\$.
share|improve this answer
discard
