Tell me more ×
We are designing a circuit which should be powered directly from mains (230VAC), and have in the previous design used a normal transformer.
But in the next design we would like to use an AC-DC converter, since this could make our design more flexible with possible input of 120VAC to 230VAC 50/60Hz.
The output of the converter is preferred to be 5VDC but could be higher.
I have found the bp5048-15 from ROHM, which would do the job.
www.rohm.com/products/databook/pm/pdf/bp5048-15.pdf
Does anyone have a better or cheaper solution?
EDIT: wall adaptor is not an option, we need to supply the product directly with mains.
share|improve this question
And using an off the shelf power adapter INSIDE the case? – clabacchio Mar 4 '12 at 10:09
It all needs to be mounted on one pcb. We have limited space. – JakobJ Mar 4 '12 at 10:41
Fine, but it's hard to reach the same livel of integration of this – clabacchio Mar 4 '12 at 10:47
Lots of companies make small "power bricks" intended to be embedded into other products. They are usually already safety-certified, which is important if you want to sell this publicly. – Olin Lathrop Mar 4 '12 at 14:40
1 Answer
up vote 1 down vote accepted
A Power Integrations TinySwitch can also be used to make a simple non-isolated rail for low-power applications. I've had success with these parts in the past.
http://www.powerint.com/en/products/tinyswitch-family
(apologies for the pasted link, SE sites with iOS Safari are painful to use)
share|improve this answer
Thanks, I will go with one of the integrated power switches. Probably one from ROHM, since they meet our demands better. – JakobJ Mar 6 '12 at 8:47
discard
