I need information about how to set a load sharing devices (woodward brand 2301 A), because when it's working parallel is always take over the load to high and caused reverse power protection active, are there any explanation regarding to those problem's
thank you for your attention and cooperation
PS: We used SPM-A for synchronizer
Woodward 2301A Speed Control
The Woodward 2301A Speed Control controls the speed or load of diesel or gas engines, or steam or gas turbines.
The unit provides control in the isochronous mode, with droop available through an externally wired potentiometer. The isochronous mode is used for constant speed of the controlled prime mover as long as it is able to provide power to satisfy the load.
The - 2301A Speed Control is compatible with Woodward SPM-A synchronizers, load sensors, and other power generation controls. These controls can be added to the system at any time, using the auxiliary or SPM inputs to the 2301A Speed Control. The 2301A Speed Control is available for forward- or reverse-acting applications, and can be used with single or tandem actuators. High voltage models accept 88 to 132 Vac or 90 to 150 Vdc, and low voltage models accept 10 to 40 Vdc supply for control power.
