Tell me more ×
I need to convert the following PIC assembly code (below) to an 8051 assembly. It is an inline assembly code. Actually, I intend to convert it to C. I am not familiar with the PIC MCU so I do not understand much of what happens. If I can an understanding of each instruction, I will try and input the equivalent assembly. Or better still, I will appreciate if I can get an equivalent 8051 assembly code of it. "toRotate" is a 32 bit variable. Thanks
    _asm
    movlb toRotate
    bcf STATUS,0,0
    btfsc toRotate+3,7,1
    bsf STATUS,0,0
    rlcf toRotate+0,1,1
    rlcf toRotate+1,1,1
    rlcf toRotate+2,1,1
    rlcf toRotate+3,1,1
    _endasm
This is the entire code below.....I really want to know what is done here. My intention is to convert it to C language.
DWORD leftRotateDWORD(DWORD val, BYTE bits)
    BYTE i, t;
    DWORD_VAL toRotate;
    toRotate.Val = val;
    for(i = bits; i >= 8u; i -= 8)
        t = toRotate.v[3];
        toRotate.v[3] = toRotate.v[2];
        toRotate.v[2] = toRotate.v[1];
        toRotate.v[1] = toRotate.v[0];
        toRotate.v[0] = t;
    for(; i != 0u; i--)
        _asm
        movlb toRotate
        bcf STATUS,0,0
        bsf STATUS,0,0
        rlcf toRotate+0,1,1
        rlcf toRotate+1,1,1
        rlcf toRotate+2,1,1
        rlcf toRotate+3,1,1
        _endasm
    return toRotate.Val;
share|improve this question
up vote 2 down vote accepted
Your code snippet is for a PIC 18. It is a naively written routine to rotate the 32 bit variable toRotate left one bit. Here is the code with some annotation:
         movlb   toRotate    ;set bank for access to target variable
         bcf     STATUS, C   ;init bit to shift in to 0
         btfsc   toRotate+3, 7 ;bit to shift in really is 0 ?
         bsf     STATUS, C   ;no, set it to 1
         rlcf    toRotate+0, 1 ;do the left shift by one bit
         rlcf    toRotate+1, 1
         rlcf    toRotate+2, 1
         rlcf    toRotate+3, 1
share|improve this answer
Thanks Olin. I am actually working on an HASH algorithm. I got this code from the MicroChip TCP/IP Stack. But I want to believe that i can used it for an 8 bit MCU, because I am much of an 8051 guy. Thanks – Paul A. Mar 9 '12 at 15:23
Please I edited the question with the code. Thanks – Paul A. Mar 9 '12 at 15:43
As Olin Lathrop said, it's a 32-bit left rotate.
Many compilers (a) recognize this idiom as a "32-bit rotate":
DWORD leftRotateDWORD(DWORD x, BYTE shift){
    y = (x << shift) | (x >> (32 - shift));
Those compilers will emit a single 32 bit rotate instruction on processors that have such an instruction, or a highly optimized sequence on other processors.
You might save a lot of time in testing and debugging by using one of the freely available implementations of SHA256 or SHA-3 proposed algorithms: ( a b c d e )
discard
