I'm currently doing some research for a project where I'd have a number of microcontrollers (say 5 ATtinys or if I manage to bring power consumption down, maybe even ATmegas) which I want to power from a single category 5e cable. I don't think that I'd need more than 100 meters of cable length (and I think that as much as 50 m may be enough), but I'd like to project for the worst case. I don't think that maximum power consumption is going to be more than 100 mA for the all devices on the cable. The idea now is that the microcontroller will check optotransistor for light level and based on that turn on or off a low-power LED.
I picked the category 5e cable because it's relatively small (and the diameter of the cable is a factor here, since I'm trying to fit in with already existing infrastructure), has 4 pairs of wires (which gives me some flexibility) and is commonly available.
So here are some of my thoughts on this topic:
According to wikipedia, I calculated that I'd have resistance of \$8.422 \mbox{ } \Omega \$ in one way on the cable. So total resistance of one pair would be \$16.844 \mbox{ } \Omega \$. This would give me a voltage drop of 1.6 V at the end of the cable, assuming 100 mA load. So I plan to use 5.5 input voltage which gives me 3.9 V at the end and is within operational range of the microcontroller family I'm planning to use. Now, since I'm using cat5e cable, I could use two pairs of wires for lower resistance and get voltage drop as low as 0.84 V. This would leave me with two free pairs.
I'm also considering adding "tank" capacitors in the \$1000 \mbox{ } \mu F\$ range near each microcontroller to provide some localized power sources in addition to standard decoupling capacitors I'd use. The size of the capacitors isn't such a problem, so I could make it even larger to somewhat mitigate the voltage drop caused by the cable.
With that, I think I covered the basics of the power problem. The part which is a bit fuzzy to me is how to deal with switching noise of the microcontrollers. I believe that the larger capacitors acting as tanks and a bit more decoupling capacitors could help here. There's also the Atmel's recommendation to put a small coil in series with the Vcc pin before first decoupling capacitor which should force the microcontroller to use more power from the capacitors and suppress a little bit the noise on the line. What I'm not so sure here is should I look into more complicated filter designs for the power line. The environment I'll be using this is basically a residential house, so I don't expect too much outside interference.
A problem with interference could be the two other pairs. Some of the adjacent microcontrollers may need to communicate with each-other, so I plan to reserve the two pairs for that, but I don't expect the data rates to be too high since I'd probably be using 2400 b/s.
So any comments, improvement ideas or suggestions?
