Tell me more ×
I have just recently bought a few different ic's from Mouser.com, not thinking i never even looked to see if i could use them. I Wound up getting a few Azoteq IQS128 capacitive touch sensors, but I have absolutely no clue which pins are which and how to wire them to an arduino. Any help would be appreciated.
share|improve this question
Have you read the datasheed? It's a load of informations about using the component. But to wire it phisically you need to put the smt package in something that can fit with Arduino...which means a small board or a socket – clabacchio Mar 15 '12 at 23:53
The datasheet is available on http://www.azoteq.com - see the pinout there.
The effective operation of the IQS128 is dependent on good de-coupling at the VDDHI and VREG lines (see the reference designs)
If you have ordered 957-IQS12800100TSR you will have a proximity output on pin3.
If you have ordered 957-IQS12800000TSR then pin3 is an input (ENABLE/DISABLE). You will have to pull pin3 high in order to enable the IQS128.
See the manual for some information on the layout used on the 957-IQS128EV01.
Buying the 957-IQS128EV01 would give you a module that can be quickly wired/plugged into your design.
share|improve this answer
Azoteq provides some design quidelines for capacitive touch sensors as well as a simple schematic for wiring up the IQS128. So you would connect your Arduino to the output line. The breakout board schematics might also give you some ideas.
protected by W5VO Apr 2 at 20:27
This question is protected to prevent "thanks!", "me too!", or spam answers by new users. To answer it, you must have earned at least 10 reputation on this site.
