Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
We see a lot of poorly drawn schematics here. A few times people have actually asked for critiques of their schematics. This question is intended as a single repository on schematic drawing rules and guidelines we can point people to.
So the questions is, what do you think are rules and guidelines for drawing good schematics?
Note that this is about schematics themselves, not about the circuits they represent.
share|improve this question
up vote 254 down vote accepted
+50
A schematic is a visual representation of a circuit. As such, its purpose is to communicate a circuit to someone else. A schematic in a special computer program for that purpose is also a machine-readable description of the circuit. This use is easy to judge in absolute terms. Either the proper formal rules for describing the circuit are followed and the circuit is correctly defined or it isn't. Since there are hard rules for that and the result can be judge by machine, this isn't the point of the discussion here. This discussion is about rules, guidelines, and suggestions for good schematics for the first purpose, which is to communicate a circuit to a human. Good and bad will be judged here in that context.
Since a schematic is to communicate information, a good schematic does this quickly, clearly, and with low chance of misunderstanding. It is necessary but far from sufficient for a schematic to be correct. If a schematic is likely to mislead a human observer, it is a bad schematic whether you can eventually show that after due deciphering it was in fact correct. The point is clarity. A technically correct but obfuscated schematic is still a bad schematic.
Some people have their own silly-ass opinions, but here are the rules (actually you'll probably notice broad agreement between experienced people on most of the important points):
  1. Use component designators
    This is pretty much automatic with any schematic capture program, but we still often see schematics here without them. If you draw your schematic on a napkin and then scan it, make sure to add component designators. These make the circuit much easier to talk about. I have skipped over questions when schematics didn't have component designators because I didn't feel like bothering with the second 10 kΩ resistor from the left by the top pushbutton. It's a lot easier to say R1, R5, Q7, etc.
  2. Clean up text placement
    Schematic programs generally plunk down part names and values based on a generic part definition. This means they often end up in inconvenient places in the schematic when other parts are placed nearby. Fix it. That's part of the job of drawing a schematic. Some schematic capture programs make this easier than others. In Eagle for example, unfortunately there can only be one symbol for a part. Some parts are commonly placed in different orientations, horizontal and vertical in the case of resistors for example. Diodes can be placed in at least 4 orientations since they have direction too. The placement of text around a part, like the component designator and value, probably won't work in other orientations than it was originally drawn in. If you rotate a stock part, move the text around afterwards so that it is easily readable, clearly belongs to that part, and doesn't collide with other parts of the drawing. Vertical text looks stupid and makes the schematic hard to read.
    I make separate redundant parts in Eagle that differ only in the symbol orientation and therefore the text placement. That's more work up front, but makes it easier when drawing a schematic. However, it doesn't matter how you achieve a neat and clear end result, only that you do. There is no excuse. Sometimes we hear whines like "But CircuitBarf 0.1 doesn't let me do that". So get something that does. Besides, CircuitBarf 0.1 probably does let you do it, just that you were too lazy to read the manual to learn how, and too sloppy to care. Draw it (neatly!) on paper and scan it if you have to. Again, there is no excuse.
    For example, here are some parts at different orientations. Note how the text is in different places relative to parts to make things neat and clear.
    Don't let this happen to you:
    Yes, this is actually a small snippet of what someone dumped on us here.
  3. Basic layout and flow
    In general it is good to put higher voltages towards the top, lower voltages towards the bottom, and logical flow left to right. That's clearly not possible all the time, but at least a general higher level effort to do this will greatly illuminate the circuit to those reading your schematic.
    One noteable exception to this are feedback signals. By their very nature, they feed "back" from downstream to upstream, so they should be shown sending information opposite of the main flow.
    Power connections should go up to positive voltages and down to negative voltages. Don't do this:
    There wasn't room to show the line going down to ground because other stuff was already there. Move it. You made the mess, you can unmake it. There is always a way.
    Following these rules causes common subcircuits to be drawn similarly most of the time. Once you get more experience looking at schematics, these will pop out at you and you will appreciate this. If stuff is drawn every which way, then these common circuits will look visually different every time and it will take others longer to understand your schematic. What's this mess, for example?
    After some deciphering you realize "Oh, it's a common emitter amplifier. Why didn't that #%&^$@#$% just draw it like one in the first place!?":
  4. Draw pins according to function
    Show pins of ICs in position relevant to their function, NOT HOW THEY HAPPEN TO STICK OUT OF THE CHIP. Try to put positive power pins at top, negative power pins (usually grounds) at bottom, inputs at left, and outputs at right. Note that this fits with the general schematic layout as described above. Of course this isn't always reasonable and possible. General purpose parts like microcontrollers and FPGAs have pins that can be input and output depending on use and can even vary at run time. At least you can put the dedicated power and ground pins at top and bottom, and possibly group together any closely related pins with dedicated functions, like crystal driver connections.
    ICs with pins in physical pin order are difficult to understand. Some people use the excuse that this aids in debugging, but with a little thought you can see that's not true. When you want to look at something with a scope, which question is more common "I want to look at the clock, what pin is that?" or "I want to look at pin 5, what function is that?". In some rare cases you might want to go around a IC and look at all the pins, but the first question is by far more common.
    Physical pin order layouts obfuscate the circuit and make debugging more difficult. Don't do it.
  5. Direct connections, within reason
    Spend some time with placement reducing wire crossings and the like. The recurring theme here is clarity. Of course drawing a direct connection line isn't always possible or reasonable. Obviously it can't be done with multiple sheets, and a messy ratsnest of wires is worse than a few carefully chosen "air wires".
    It is impossible to come up with a universal rule here, but if you constantly think of the mythical person looking over your shoulder trying to understand the circuit from the schematic you are drawing, you'll probably do alright. You should be trying to help people understand the circuit easily, not make them figure it out despite the schematic.
  6. Design for regular size paper
    The days of electrical engineers having drafting tables and being set up to work with D size drawings are long gone. Most people only have access to regular page-size printers, like for 8 1/2 x 11 inch paper here in the US. The exact size is a little different all around the world, but they are all roughly what you can easily hold in front of you or place on your desk. There is a reason this size evolved as a standard. Handling larger paper is a hassle. There isn't room on the desk, it ends up overlapping the keyboard, pushes things off your desk when you move it, etc.
    The point is design your schematic so that individual sheets are nicely readable on a single normal page, and on the screen at about the same size. Currently, the largest common screen size is 1920 x 1080. Having to scroll a page at that resolution to see necessary detail is annoying.
    If that means using more pages, go ahead. You can flip pages back and forth with a single button press in Acrobat Reader. Flipping pages is preferable to panning a large drawing or dealing with outsized paper. I also find that one normal page at reasonable detail is a good size to show a subcircuit. Think of pages in schematics like paragraphs in a narrative. Breaking a schematic into individually labeled sections by pages can actually help readability if done right. For example, you might have a page for the power input section, the immediate microcontroller connections, the analog inputs, the H bridge drive power outputs, the ethernet interface, etc. It's actually useful to break up the schematic this way even if it had nothing to do with drawing size.
    Here is a small section of a schematic I received. This is from a screen shot displaying a single page of the schematic maximized in Acrobat Reader on a 1920 x 1200 screen.
    In this case I was being paid in part to look at this schematic so I put up with it, although I probably used more time and therefore charged the customer more money than if the schematic had been easier to work with. If this was from someone looking for free help like on this web site, I would have thought to myself screw this and gone on to answer someone else's question.
  7. Label key nets
    Schematic capture programs generally let you give nets nicely readable names. All nets probably have names inside the software, just that they default to some gobbledygook unless you explicitly set them.
    If a net is broken up into visually unconnected segments, then you absolutely have to let people know the two seemingly disconnected nets are really the same. Different packages have different built-in ways to show that. Use whatever works with the software you have, but in any case give the net a name and show that name at each separately drawn segment. Think of that as the lowest common demoninator or using "air wires" in a schematic. If your software supports it and you think it helps with clarity, by all means use little "jump point" markers or whatever. Sometimes these even give you the sheet and coordinates of one or more corresponding jump points. That's all great, but label any such net anyway.
    The important point is that the little name strings for these nets are derived automatically from the internal net name by the software. Never draw them manually as arbitrary text that the software doesn't understand as the net name. If separate sections of the net ever get disconnected or separately renamed by accident, the software will automatically show this since the name shown comes from the actual net name, not something you type in separately. This is a lot like a variable in a computer language. You know that multiple uses of the variable symbol refer to the same variable.
    Another good reason for net names is short comments. I sometimes name and then show the names of nets only to give a quick idea what the purpose of that net is. For example, seeing that a net is called "5V" or "MISO" could help a lot in understanding the circuit. Many short nets don't need a name or clarification, and adding names would hurt more due to clutter than they would illuminate. Again, the whole point is clarity. Show a meaningful net name when it helps in understanding the circuit, and don't when it would be more distracting than useful.
  8. Keep names reasonably short
    Just because your software lets you enter 32 or 64 character net names, doesn't mean you should. Again, the point is clarity. No names is no information, but lots of long names are clutter, which then decreases clarity. Somewhere in between is a good tradeoff. Don't get silly and write "8 MHz clock to my PIC", when simply "CLOCK", "CLK", or "8MHZ" would convey the same information.
    See this ANSI/IEEE standard for recommended pin name abbreviations.
  9. Upper case symbol names
    Use all caps for net names and pin names. Pin names are almost always shown upper case in datasheets and schematics. Various schematic programs, Eagle included, don't even allow for lower case names. One advantage of this, which is also helped when the names aren't too long, is that they stick out in regular text. If you do write real comments in the schematic, always write them in mixed case but make sure to upper case symbol names to make it clear they are symbol names and not part of your narrative. For example, "The input signal TEST1 goes high to turn on Q1, which resets the processor by driving MCLR low.". In this case it is obvious that TEST1, Q1, and MCLR refer to names in the schematic and aren't part of the words you are using in the description.
  10. Show decoupling caps by the part
    Decoupling caps must by physically close to the part they are decoupling due to their purpose and basic physics. Show them that way. Sometimes I've seen schematics with a bunch of decoupling caps off in a corner. Of course these can be placed anywhere in the layout, but by placing them by their IC you at least show the intent of each cap. This makes it much easier to see that proper decoupling was at least thought about, more likely a mistake is caught in a design review, and more likely the cap actually ends up where intended when layout is done.
  11. Dots connect, crosses don't
    Draw a dot at every junction. That's the convention. Don't be lazy. Any competent software will enforce this anyway, but surpringly we still see schematics without junction dots here occasionally. It's a rule. We don't care whether you think it's silly or not. That's how it's done.
    Sort of related, try to keep junctions to Ts not 4-way crosses. This isn't as hard a rule, but stuff happens. With two lines crossing, one vertical the other horizontal, the only way to know whether they are connected is whether the little junction dot is present. In past days when schematics were routinely photocopied or otherwise optically reproduced, junction dots could dissappear after a few generations, or could sometimes even appear at crosses when they weren't there originally. This is less important now that schematics are generally in a computer, but it's not a bad idea to be extra careful. The way to do that is to never have a 4-way junction.
    If two lines cross, then they are never connected, even if after some reproduction or compression artifacts it looks like there maybe is a dot there. Ideally connections or crossovers would be unambiguous without junction dots, but in reality you want as little chance of misunderstanding as possible. Make all junctions Ts with dots, and all crossing lines are therefore different nets without dots.
Look back and you can see the point of all these rules is to make it as easy as possible for someone else to understand the circuit from the schematic, and to maximize the chance that understanding is correct.
  • Good schematics show you the circuit. Bad schematics make you decipher them.
There is another human point to this too. A sloppy schematic shows lack of attention to detail and is a irritation and insult to anyone you ask to look at it. Think about it. It says to others "Your aggrevation with this schematic isn't worth my time to clean it up" which is basically saying "I'm more important than you are". That's not a smart thing to say in many cases, like when you are asking for free help here, showing your schematic to a customer, teacher, etc.
Neatness and presentation count. A lot. You are judged by your presentation quality every time you present something, whether you think that's how it should be or not. In most cases people won't bother to tell you either. They'll just go on to answer a different question, not look for some good points that might make the grade one notch higher, or hire someone else, etc. When you give someone a sloppy schematic (or any other sloppy work from you), the first thing they're going to think is "What a jerk". Everything else they think of you and your work will be colored by that initial impression. Don't be that loser.
share|improve this answer
12
My ten cents: though I love to use colour to disambiguate on-screen, I prefer the way monochrome schematics look in print (or PDF). Conventions and æsthetics evolved for monochrome work, and not everyone has access to a colour printer/photocopier so colour information may be lost. I also like to not depend on colour (one of my co-workers is colour-blind, which occasionally leads to semi-amusing incidents involving colour-coded LED status lights. So I've become very sensitive to this). – Alexios Mar 17 '12 at 21:21
As in programming, readability counts. From the Zen of Python: "Beautiful is better than ugly." – shimofuri Mar 18 '12 at 11:07
10
Maybe it's because of my programming background, but I find that I often prefer "air wires" for many things. If I see two pins on the CPU labeled "DATA_TO_FTDI" and "DATA_FROM_FTDI", I can tell at a glance that those pins go to (or at least should) the data RX/TX pins on the FTDI chip. A glance at the FTDI chip can confirm that. I can then check those names against the definitions of the pins on the device (since some devices which behave as communication bridges use TX as an output (they transmit data on that pin), while others use it as an input (accepting data to be transmitted elsewhere). – supercat Mar 21 '12 at 17:20
@supercat - The issue with air-wires is that even if where they go seems apparent, you can never be sure (without an exhaustive search), that you have found everywhere they go. For your "DATA_TO_FTDI" example, what if there is a serial activity LED on that bus? Or another device sharing the serial interface? I can never be sure without manually looking over EVERY net-label on the entire schematic. – Connor Wolf Mar 21 '12 at 21:22
The TIA schematics found at atariage.com/2600/archives/schematics_tia/index.html make heavy use of air wires, but I can't imagine that drawing in all the "air wired" connections would make them any clearer. Even without automated systems to find net connections, I can't imagine that drawing in all the connections to HΦ1/HΦ2, or D0-D7, or the write-address decodes from the bottom of page 2, etc. would make the schematics any clearer. Actually, I'm rather impressed with those schematics; indeed, they're better than a lot of newer ones. – supercat Mar 21 '12 at 22:12
1. Show Your Work A Schematic Diagram is intended to be the documentation of a circuit. As such, I highly recommend including any simple equations that may be used. This includes LED current calculations, filter corner frequencies, etc. Show your work, so that the next guy who has to read the schematic can check it easily.
2. Indicate UART Direction Since UART lines are not always clear which way they are flowing, add a little arrow next to each line to show the direction.
3. Be Consistent Don't use VDD in one place and 3V3 in another. Standardize.
4. Annotate Liberally This is like comments in source code. If you copied a circuit from a datasheet, put the reference on the schematic so that someone else (or you) can check it later.
Here's my two cents
1. Break it down Break down your design into modules. Put a block diagram of the system on the first page of the schematic
2. Answer who, what, where, when, why Who - For each module page, label "who" the module connects to. Lay it out left to right so it reads like English.
What - In the title, indicate what the module is. For instances where there are multiple I/O blocks (i.e. UART and USB), label it as such on the page.
Where - Use free text in the CAD program to indicate component placement. For example - a decoupling cap should be placed as close to the IC as possible. This will act as a quicker reference when laying out the board than referring to some other documentation.
When - Are there any timing considerations such as power supply sequencing or power fail circuitry? Put these requirements not only in a design doc but in free text on the pertinent module page.
Why and How - This belongs in an accompanying design document to verify such things as a. Scope - what does the circuit do, what does it not do as agreed upon by the stakeholders for the project. b. Theory of operation c. Rationale of why the approach was taken as opposed to others. This is crucial as it serves as a history for the circuit down the road when you (or someone else) inherits/ports the design to be mindful of the same decisions as the original designer. d. Layout considerations e. References to other documentation. f. Power dissipation calculations - prove not only that it works, but that calculated power dissipation for all components is some degree less than the rating for the component AND at all operational temperatures.
3. Style This is up to you and the rest of the team, but in general I prefer the following a. Title page/block diagram b. One "block" per page, partitioning large pin-count components (i.e. a microcontroller) into meaningful discrete symbols. This takes some time to do, but is well worth the readability.
The modularization also allows you to "tear a page out" and re-use it in other designs
c. For each component indicate the reference designator, whether or not is is a no-pop, the value/tolerance of the component, the power rating where applicable, and the package size and some way of determining the manufacturer part number. The last point will help you to make common some of the components to reduce setup manufacturing costs and to make a judgement call if some of the design parameters can be relaxed to reduce the number of different components used on the board. For vertically aligned components, place this text on the left. For horizontally aligned components, place this text above the component.
d. Lay out the circuit from left to right indicating where the module interfaces are with text
e. For power rails clarity, DO NOT USE VDD or VCC as they are ambiguous. Make a new symbol for explicitly declaring what the voltage is. Same thing for ground (i.e. GND for ground and AGND for analog ground).
A couple of points in addition to the ones posted above. The first answer is fairly heroic but there's one thing I don't agree with.
Pin order in schematic symbol.
Why to reorder pins It makes aesthetically more pleasing schematic that may be easier to interpret depending on how the pins are laid out.
Why not to reorder pins It's asking for trouble, period. In the datasheet the pins are given as they are in the physical chip so you create a significant source of error if you start rearranging them. Not only it makes prototyping more difficult, you're also inviting errors in the physical pinout. In a design review pinouts are compared and if they're mishmash, it's easy to get mixed up.
Another comment on "air wires" Just don't do it. Instead use ports which require you to explicitly make a connection between two nets in same or separate schematic sheets. If you allow nets to connect without ports/off-pages, you open a huge can of worms as apparently unrelated nets may be shorted in layout.
Don't pack too much stuff on a page People may start complaining if you schematic is thirty pages but the alternative is having rats nest of confusing wiring between parts. Break up the schematic into logical blocks of circuits and stick them to separate pages as necessary.
Leave enough space between pins Many premade schematic symbols pack the device pins as tightly as possible. While this minimizes the area of a symbol, it also makes the circuit more difficult to read as you have connections converging from "outside" into the tightly packed pins. You should leave enough space so you can add series resistors staggered.
Reference designators You should obviously have reference designators in schematic and layout. For anything more complex these need to be ordered. There are two approaches to it.
  1. You can ask the schematic capture program to label these so each page has it's own prefix. This way it's easy to find any given part in the BOM from the schematic. And also ECO is easier to follow as you know which page the changes are for. The downside of this is that you end up with long reference designators and finding the part in the layout can be difficult.
  2. You can ask the layout program to label these. This way you will have ordered references on the PCB which makes it much easier to locate resistor R347. Preferably on a larger PCB this should be cordoned into quadrants (sextants, octants..). The downside is that it's not obvious where the part is in the schematic. You just can't win here, either schematic is easier to read or the layout is.
I just disagree about pin order. Schematics shouldn't necessarily have anything to do with the physical layout of the chip. For example, op amps should look like op amps in a schematic. A quad op amp should look NOTHING like the chip. Also, when dealing with complicated high pin counts, the gates should be split up into functional units. – Scott Seidman Apr 19 at 12:56
Good points, but I agree with Scott that avoiding reordering pins is nonsense. With small chips, sure, but schematics are 100% less confusing if instead of having wires criss crossing everywhere, you reorder the pins on a chip and just make sure they are labeled properly. If out of order pins on a schem is enough to confuse someone, they probably shouldn't be messing around with the board to begin with. His op amp point is also very valid. – I. Wolfe Apr 19 at 13:08
Opamps are a special case as I'm sure you'll agree, similar to transistors etc. If you end up with a respin because your rearranging of schematic pins led into an invalid footprint, you didn't exactly do anyone favours. – Barleyman Apr 19 at 13:14
protected by W5VO Sep 10 '13 at 16:33
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
Would you like to answer one of these unanswered questions instead?
