Tell me more ×
Theoretically, would it be possible to do a short circuit with a cheated plug?
How can cheat it?
Added:
Wikipedia on "cheater plug"
  • A cheater plug, AC ground lifter or three-prong/two-prong adapter is an adapter that allows a NEMA 5-15P grounding-type plug (three prongs) to connect to a NEMA 1-15R non-grounding receptacle (two slots).1 The use of such an adapter avoids the need to replace receptacles, but is potentially hazardous, if the grounding tab is not actually connected to electrical ground.2[3] An alternative identified in the U.S. and Canadian electrical codes is to replace the outlet with a GFCI breaker outlet.[3]
Cheater Plug from here (Wikipedia)
A cheater plug, with metal grounding tab (the leftmost blade and cavity are wider, for polarization purposes)
share|improve this question
You mean you want to trip the breaker? – Kellenjb Mar 21 '12 at 20:58
@kellenjb The all electric circuit. – Garmen1778 Mar 21 '12 at 21:00
What is the electric circuit that you speak of? – Kellenjb Mar 21 '12 at 21:00
@kellenjb A simple electric circuit of a garage. – Garmen1778 Mar 21 '12 at 21:13
@RussellMcMahon - It's great that you've tried to educate the user, but you've changed the question a lot and it's still not answerable. The original question is How to turn off an electrical installation with a simple cheated plug? Theoretically, would it be possible to do a short circuit with a cheated plug? How can cheat it? which doesn't make any sense. WRT "Any Spanish speakers here?" I've had 4 years of Spanish, and nothing but the implied subject 'I' in "How can cheat it" is identifiable. If you want to ask and self-answer "What are cheater plugs and are they safe?" go ahead. – Kevin Vermeer Jun 8 '12 at 19:26
show 7 more comments
closed as not a real question by Olin Lathrop, Kellenjb, starblue, Kevin Vermeer Jun 8 '12 at 19:22
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
1 Answer
up vote 3 down vote accepted
It's not completely obvious what you are trying to do BUT it's almost certainly not safe. You may kill yourself or somebody else.
If you can explain in much more detail and simple words we may be able to help. (Small and simple because language differences mean more complicated words may be misunderstood.)
"Cheater Plugs" = mains power adapters that break the connectivity of the earth circuit, are sometimes used in audio systems to remove ground connections which are causing "hum loops". This is a very dangerous practice which can lead to electric shock.
In the text below "GFCI" = Ground Fault Current Interrupter = device to remove power automatically if even a very small amount of the current is bypassed improperly by eg your finger. If you get a shock then it turns off (almost) instantly. Using GFCIs is a very very good idea.
Lots and lots of references to GFCIs
The following was written with USA installations in mind but also applies in Spain.
Wikipedia notes:
(1) Use of Cheater plugs can kill enter image description here
  • ... The cheater plug is also recognized as a safety hazard in laboratory settings. For example, in August 2005, Tarun Mal, an associate professor at Cleveland State University, was electrocuted when he plugged a defective fluorescent lamp into a time switch using a cheater plug.[8] Subsequently, the state of Ohio issued seven citations to the university for unsafe electrical conditions.[8] The Scientist notes that four of the University's seven environmental safety experts agreed that use of the cheater plug "is not uncommon in US university labs".[8] Jim Kaufman, CEO of the Laboratory Safety Institute, says, "When you inspect labs, it's not unusual to find anywhere from one to seven that way."[8]
(2) Alternatives - only one is safe:
  • There are several alternatives for connecting newer appliances to two-prong receptacles without rewiring the building: removing the grounding pin of the plug, replacing the receptacle with a three-prong outlet, or replacing the receptacle with a GFCI; only the last (GFCI) is safe.
    • Removing the grounding pin of the appliance’s plug is unsafe, and leaves the appliance without proper grounding even when relocated and plugged into a properly grounded three-prong receptacle.
    2 Additionally, since most NEMA 5-15P plugs have both current-carrying prongs the same width and rely on the ground pin for correct orientation, removing it allows insertion of the plug with hot and neutral wires reversed, creating an additional hazard.
    Replacing the receptacle with the three-prong type and leaving the ground screw unconnected is just as unsafe as using a cheater plug, but has the additional disadvantage that subsequent users of the outlet may not be aware that it is not properly grounded. However, if the ground screw of the receptacle is connected to the neutral side, electric shock is possible even if the appliance is properly functioning. This is called a "false" or "bootleg" ground and is a serious safety hazard[9] often undetected by common receptacle testers.[10]
    Replacing the receptacle with a GFCI receptacle is the safest alternative. If a GFCI receptacle is properly functioning, then it will shut off the power to a faulty appliance to prevent electric shock. As a safe option that protects all appliances plugged into that receptacle, the National Electrical Code permits such replacement if the installer marks the GFCI as having "No Equipment Ground".[3]
share|improve this answer
