Tell me more ×
Wikipedia explains the basics about the markings of capacitors, here. It lacks many markings most of which confuses me:
Ceramic brown-yellowish cap
  • 104 K5K (small ) --- what is the end "5K"? (Cannot be 5 kelvin as operating temperature!?)
  • 10 (box box, perpendicular right upermost corner) 35+ (Tantalum Cap, bigger variant of the last one
  • 154 C1K (what is C1K, some other notation to Wikipedia?)
Orange Ceramic
  • 333 K5X (what is 5X? X roman numeral?)
Brown Circle Slit
  • 10n (no other marking, what is the op.temp?) (Diameter: 7.5mm)
  • 27J 100V (what is 27J?) (Diameter: 4.9mm, blackdot on the head)
Blue Slit Square
  • (triangle) 104K X7R50 (What is triangle? X7R50? Operating V?) (side = 4.9mm)
  • 104 (side = 2.6mm, op.V? Tolerance?)
Questions about the bracketed
  1. How to know operating V without its explicit marking?
  2. What do the symbols, such as squares, plus-sign and triangle, mean?
  3. Can you evaluate the operating voltage from the size of the capacitor in the case when no marking or poor marking is given?
share|improve this question
Related question (maybe this can be considered a duplicate): electronics.stackexchange.com/questions/16636/… – Denilson Sá Aug 11 '11 at 23:09
Generally there are two labels on most caps.
The first is the value, which is written:
<Digit><Digit><Exponential Notation>
It's generally in picofarads.
The second is the TempCo, or Temperature Coefficient. There are two common specification systems, namely EIA Class 1 and Class 2. This is the mysterious second label in most cases. It's generally written:
<Letter><Number><Letter> (though there are a few variations)
There are a few common tempcos - NP0/C0G, X7R, X5R, Y5V, Z5U
Tantalums, and bigger ceramics often also have the voltages:
<voltage number><+ or v>
Therefore:
  • 104 K5K (small )
    The value is 10e4, or 100,000 pf / 0.1 uF. The tempco is not standard, may be manufacturer specific/extended range.
  • 10 (box box, perpendicular right upermost corner) 35+ (Tantalum Cap, bigger variant of the last one)
    Need a picture to be more specific, it's very likely a 35v rated cap, from the 35+.
    Capacitance is 15e4, or 150,000 pf / 0.15 uF. Looks to be a Class 1 dielectric from the C1K. Is this a large cap? the tempco is very good.
  • Orange Ceramic 333 K5X (what is 5X? X roman numeral?)
    33e3, or 33,000 pf / 33 nF. Tempco is either manufacturer specific, or incorrectly read.
  • Brown Circle Slit 10n (no other marking, what is the op.temp?) (Diameter: 7.5mm)
    10n very likely means 10 nf, or 10,000 pf. If it's ceramic, it's probably 50v. Likely a cheap part, if the voltage is not marked.
    Voltage rating is self evident. J is the multiplier, and I think there is a standard for letter multipliers, but I do not remember where to find it.
  • Blue Slit Square (triangle) 104K X7R50 (What is triangle? X7R50? Operating V?) (side = 4.9mm)
    10e4 is the value - 100,000 pf / 0.1uF Tempco is X7R. the 50 is likely the voltage rating.
    10e4 - 100,000 pf / 0.1uF. Voltage is not known
This is kind of a guess. Anyways, it should show how this sort of thing works. Older parts may vary wildly, and it's always just a guideline. The best thing to do is find the cap's actual datasheet.
A lot of the parts have unusual tempcos. Is this a automotive/extreme duty part which contains these components?
share|improve this answer
Here's a staring point. If you know the type of capacitor that you have, but not what the value is, have a look at (for example) Farnell website and search for that part type. Then you can get a data sheet which usually explains things nicely.
Could you please post real links! – starblue Jun 8 '10 at 19:24
The "K5K", "K5X", "C1K" that doesn't match a temperature characteristic (X7R, NPO, C0G, etc.) is a manufacturer-dependent part marking to make use of the limited space available on the part.
If you look at some of the major manufacturers' datasheets for radial-lead ceramic capacitors, you'll see the following. Capacitance tolerance codes seem to be consistent, but otherwise there is some disparity.
  • Murata:
    • First character = capacitance tolerance (C = +/-0.25pF, D = +/-0.5pF, J = +/-5%, K = +/-10%, M = +/-20%, Z = +80%/-20%)
    • Second character = voltage rating (2 = 25VDC, 5 = 50VDC, 1 = 100VDC, 4 = 250VDC, 9 = 450VDC, 7 = 630VDC)
    • Third character = temperature characteristics (A = C0G, C = X7S/X7R, F = F/F5V, 8 = X8G/X8L, 7 = X7T)
  • AVX:
    • First character = temperature characteristics (A = C0G, C = X7R, D = X5R, E = Z5U, F = X8R, )
    • Second character = voltage rating (Z = 10VDC, 5 = 50VDC, 1 = 100VDC, 2 = 200VDC, 9 = 300VDC, 8 = 400VDC, 7 = 500VDC)
    • Third character = capacitance tolerance (C = +/-0.25pF, D = +/-0.5pF, F = +/- 1%, G = +/-2%, J = +/-5%, K = +/-10%, M = +/-20%, Z = +80%/-20%)
  • KEMET: unclear, first character is sometimes a "K" for KEMET; they use the same capacitance tolerance codes as AVX, but seem to mark with the full text of the voltage rating and temperature characteristics where possible.
2. About "+"-sign
The plus means "polarised", the source is tronixstuff's site, point "Tantalum capacitors".
More here.
Why did you not take the time to just comment on his. This is something you got because of his answer, he should be rewarded. – Kortuk Jun 10 '10 at 15:32
Kortuk: Yes and I am not taking credit of it, please, see the "the source is --". I think it is better to consider each point separately well in an answer rather than tell everything you know on a one big answer. Anyway, it is not identical it evolved to a next question which I think is now much easier to read than reading jammed comments. – hhh Jun 11 '10 at 21:05
Kortuk: cannot see a reason why you're pointing these things? There are still many points answered in 1-3. I will attack them soonish if there is no-one else to attack them. I call it self-learning and I think it is a good thing. Tronixstuff's article is just an introduction and did not cover all of points in the question. – hhh Jun 11 '10 at 21:07
discard
