I want to implement a control system I designed for a light electric motorbike. I would like to mount it as professionally as possible on the chassis. It consists of a power system pcb and a SAMC21 development board which I'll merge later once this all works properly. I have tried screwing it directly on the aluminium chassis but have found that shocks and vibrations from the horn disturbed the system or even destroyed it upon large shocks like a few hammer hits. Is there a specific way car and motorcycle manufacturers mount their electronics to make their system as robust as possible? Thank you for your help!
\$\begingroup\$ What exactly got damaged - connections working loose, or physical damage to the PCB? \$\endgroup\$– pjc50Mar 6, 2017 at 10:55
2\$\begingroup\$ When the horn is activated the LCD displays random characters. I have done some tests and verified that this was due t the actual vibrations generated by the horn. The hammer hits on the chassis, relatively far away from the pcb location actually led to physical damage to the pcb which upon power up completely grilled. I am worried that bumps on the road could lead to the same problem. \$\endgroup\$– Eliott WMar 6, 2017 at 11:18
2\$\begingroup\$ Start by defining the shock, vibration levels and g-forces for a wide range of frequencies up to at least 2 kHz. There's no point guessing or expecting folk to guess. If you want to guess then go look for special anti-shock and anti-vibration kits. \$\endgroup\$– Andy akaMar 6, 2017 at 11:19
1\$\begingroup\$ I remember having an issue with a product where the LCD would consistently stop working in units which survived a drop on the floor. Turned out the coil in the backlight circuit would easily fracture/desolder from the shock and go off the PCB. The day we discovered this, we really wished we had dropped our proto boards on the floor on purpose before producing a batch of 1000 units... \$\endgroup\$– Dmitry GrigoryevMar 6, 2017 at 16:49
\$\begingroup\$ The horn is probably causing electrical spikes which disrupt the electronics (and could, in extreme cases, cause damage). \$\endgroup\$– Hot LicksMar 7, 2017 at 1:05
Avoid ceramic capacitors and ceramic components for applications under environmental conditions that include vibrations and shocks. If you can't avoid them, choose components that use materials or constructions techniques targeted to minimise the so-called "microphonics". Also, use microphonics minimisation design strategies on your own.
Microphonics is an unwanted behavior due to the piezoelectric effect of ceramic materials. Usually, it will manifest itself as spurious voltage burst when the component is subject to mechanical vibrations or shocks. Obviously, it can wreak havoc in your circuit, upsetting digital circuits and/or triggering switching in analog circuits.
Apart from microphonics, electromechanical devices (relays, swtches, etc.) can suffer upsetting under vibration/shock.
Also, mechanical stress can dramatically affect reliability and precipitate failures unless the PCB and its enclosure is specifically design to withstand those vibration and shock levels:
- Solder joints may break up due to tension/compression forces.
- Solder joints may not break up but can apply tension force to some components and break them up (ceramic chip capacitor are a classic).
- Glued components may loose (if glue is too stiff).
- Electromechanical components may latch-up (permanent damage), especially relays.
- PCBs may break up, either externally or internally and traces may get damaged.
- etc.
All these issues are usually addressed at design level, having the environmental specifications in mind. The specifications drive all the following:
- The selection of components and materials (reliable under vibration, no microphonics).
- The electrical design of the circuit (tolerance to upsets).
- The mechanical design of the PCB (higher clearance to PCB edges, etc.).
- The footprints in the PCB (bigger footprints for better solder joints wetting, etc.).
- The soldering process (reliable joints with good wetting, no cold joint, etc.).
- The mechanical interface between the circuit and its enclosure. (stiffening mechanical parts may be required to avoid resonant vibration modes).
- The mechanical design of the enclosure (to avoid vibration amplification).
- The mechanical interface between the enclosure and the place where it has to be mounted (to avoid vibration amplification and to damp vibrations and shock as much as possible).
As you can imagine, if you don't address all these things from the beginning, then you can only pray for it to work under vibration/shock and/or try to mitigate it by replacing some parts (ceramics) and trying to reduce the mechanical energy your board is getting.
1\$\begingroup\$ Avoiding ceramics should only matter if your design will actually be sensitive to the (very small) microphonics. Every single module we made at a previous automotive company of mine used ceramics all over the place because hardly anything was ever sensitive to such small signals. \$\endgroup\$– Nick TMar 6, 2017 at 21:05
For prototype devices (which should last several months and are OK to fail occasionally), it is usually enough to mount the PCB on rubber inserts instead of bare screws). This greatly reduces peak accelerations your PCB sees, while keeping your prototype accessible and requiring minimum design changes:
For commercial products which should last 10 years or more, you want something more robust. I have seen automotive electronics where parts are assembled (or even the whole device is potted) with RTV silicone, which greatly helps with both mechanical sturdiness and heat transfer.
1\$\begingroup\$ Also epoxy potting compounds, which can have higher thermal conductivity and may be more rigid. \$\endgroup\$– Chris HMar 6, 2017 at 16:42
\$\begingroup\$ Both of these are normal practices for parts made for permanent use on cars and motorcycles. \$\endgroup\$ Mar 7, 2017 at 0:01
Board flex will crack ceramic capacitors and other brittle parts, like SMD resistors (which have a ceramic body). It will also crack BGA solder joints, if any.
Lower-intensity board flex and vibrations will make X7R and related high-K ceramics act piezoelectric. This means any high impedance nodes (like a sensor, or a voltage reference) filtered by a High-K ceramic capacitor will be very noisy. Using other capacitor types solves this.
Now, there are several strategies to mitigate this:
- Use flex-resistant components (like J-lead caps, flex-termination caps, SMD parts with leads, or even thru-hole parts)
- Minimize flex and shock reaching the board itself
You can make your board stiffer by mounting it inside a solid enclosure or on a metal plate, with lots of screws. Thermal management issues must be considered.
You can orient the board in such a direction that the main shock force will be parallel to it. Forces perpendicular to the board will make it flex more than forces parallel to its length.
Now that you have a rigid metal-backed board, you can mount it (or its enclosure) to the chassis using rubber shock-mounts, or even rubber shock washers.
The idea is to avoid resonance, and create a mechanical lowpass filter without a peak in its frequency response.
2\$\begingroup\$ "You can orient the board in such a direction that the main shock force will be parallel to it. Forces perpendicular to the board will make it flex more than forces parallel to its length." This is also a good thing to consider when designing the board. If you can predict in which direction the board will likely flex, sensitive SMD components can be placed perpendicular to that direction, to strain them, as well as the soldering joints, to a minimum. \$\endgroup\$– LundinMar 6, 2017 at 13:03
One thing you'll notice in many cars is that the electronics are often mounted in an enclosure, and the enclosure is mounted to the vehicle. The enclosure may be metal or plastic, metal enclosures are connected to chassis ground and used for devices sensitive to electrical noise (e.g. radios, GPS/tracking devices).
Quite often both the mounting of the electronics to the enclosure, and the mounting of the enclosure to the chassis have some degree of damped flexibilty in them. A pcb may for example be mounted on rubber bushes into a box that's attached with plastic clips. Some retrofit devices use sticky foam pads to mount the PCB. The box also absorbs some of the large-scale flexing in the PCB.
Prototypes are often worse than production devices, as they may use bigger boards and heavier components/connectors (even through-hole).
