I have a computer that stopped working and I think the problem is the power source but I'm not sure.
I have other power source from another computer that I would like to use to test but first I would like to be sure if there is no harm to use it, if it is compatible.
The power source that I think is not working has these specs
INPUT 100V-127V/6A 60Hz 200V-240V/3A 50Hz ------OUTPUT +3.3V+5V+12V-12V-5V+5V Sb ------MAX(A) 14A 22A 8A 0.8A 0.5A 0.1A +5V &+3.3V MAX-120W
The power source that I could use to test has these specs
INPUT(50Hz-60Hz) 100V-127V~/6A 200V-240V~/3A -----OUTPUT +5V/22A +3.3V/18A +5Vfp/2A +12V/14A -12V/1A +5V AND +3.3V SHALL NOT EXCEED 150W -----MAX OUTPUT POWER: 250W
Any harm on trying that power source to test?
And just another question. What are the specs of the fuse these power supplies has inside? Are they standard?
