Tell me more ×
I've been considering building some LED lights to replace the mains-supplied lights in my house (as a more efficient alternative). For it to be worthwhile though I'd need to build an efficient UK mains converter to supply each cluster of lights.
What's the most efficient way to turn AC into ~5v to power ~10 luxeon lights?
share|improve this question
There are lights on the market that do this, here are 120v AC type store.sundancesolar.com/120voacledre.html I am assuming you are wanting to have the fun of building this, and doing it for cheaper then those lights though, which is why this is just a comment and not an answer. – Kellenjb Jun 9 '10 at 18:27
Basic Approach
The most efficient way would be to rectify the system and use high quality components to get the lowest losses possibly.
After you have rectified to DC, I would suggest using a very high efficiency buck converter.
So, rectify with high grade components to DC(focus is on low leakage here) then buck convert it to the power you need.
Warning: Safety
When you build your own system for lighting, that is using 120VAC and has high current output has the possibility for fire in failure modes. If someone is hurt or their property damage, you can probably be found liable, and possibly criminally negligent, depending on your country and their laws.
I recognize you said UK, but I will not pretend to know the laws there, I would suggest you spoke to an attorney about it if you are planning to switch your house to this. At minimum use Fuses everywhere they make sense and protect yourself from having a wiring fault and starting a fire.
The filter caps from the rectifier will have a large amount of power stored and a short after that point could easily become a fire if not protected against.
Improving on the Design
So, there is still more you can do to improve this, it just gets more complicated and will require control circuitry on your part. This control circuitry will require power, but it should be negligible with a good design compared to what you save. You will do this by having the LEDs blinking at a very high frequency with large off-time and over-current during the on-time.
LED Heating
LEDs have failure brought on by heating effects, this means there are many ways you can trick an LED. An LED Rated for 5A can be vastly overcurrent for a very short period of time without any damage done to the LED. The trick is to hit it with the current very quickly then have an off period where any heat is allowed to dissipate. The average light your eye sees will go up with lower power consumption.
I did a quick google search to attempt to give you a good example, but I failed. It seems the words involved in finding these methods are too often used in systems where things like overcurrent are a danger. You should play with it, I think you will find it surprising. I have actually done this myself, multiple times, and with excellent results. One of my professors made the duty cycle to long on purpose once to show me the changing of colors you can get in an LED due to heating also, don't do this, unless to laugh at it, because you have to bury your LED afterward.
PWM Generation
I would suggest using a very simple 555 timer circuit. This circuit is driving a motor and uses a POT, but you could easily use 2 resistors of your choice and have it hard set to it's frequency. The motor is an example load and driving an LED is significantly easier(ie. inductance is much lower). This also adds a place to add an on/off switch. By placing a switch on the branch that is used for the "on" cycle and you can disable the system.
Efficiency When Off
Make sure when you leave a room and switch off all of the lights, or whatever unit it is that you feed from each Buck converter that you are also disconnecting the rectifier and the buck converter. They will continue to drain power when the load is disconnected. This will very quickly remove any power savings you have reaped.
Results
You can read about this online, but LEDs really have the highest efficiency in low temperature applications, in room temperature you will probably not save any power over florescent lights at the same cost. You should be able to save a relative amount of power just by upgrading to high end components, but the system will cost you significantly more to implement.
share|improve this answer
TI does sell buck modules that are already made and you just solder Leads to. You should be able to find them at TI.com, if you need I can go find a link. – Kortuk Jun 9 '10 at 15:47
buy one -- for example Digikey sells 5V regulated power supplies for about US$7 and unregulated ones for less than this.
You would probably be hard pressed to make something less expensive that is safe.
sounds nice, the only reason i suggested building one was for efficiency, not for cost. – Kortuk Jun 12 '10 at 16:52
I agree. Or better, find one of the thousands of abandoned wall warts, strip off the device adapter and use that. Free! – Dirk Jun 12 '10 at 19:03
if cheap is your goal, I agree. – Kortuk Jun 13 '10 at 4:28
You can also find switch mode wall warts these days. Hit the flea markets. – XTL Aug 13 '10 at 5:39
It's not really efficient to go down to 5V and drive the power LEDs individually.
Rather, put several LEDs in series and drive them with a buck converter that regulates current. I think there are special LED driver ICs that do exactly that.
If you are uncomfortable with using line voltage directly (you should be), then you can transform it down to some intermediate voltage and rectify / filter it to drive the LEDs.
If you just want to have some standard lighting the best way is probably to buy some ready made LED lights that you can just screw in.
Here is an interesting circuit where the LEDs in series can be controlled individually, by shorting them with a FET (in german).
mine is more of an approach to try to do it yourself. I agree with this one also. It is a different approach, but just as valid. I have done this before. – Kortuk Jun 10 '10 at 0:53
Yes, there are hysteretic LED driver chips that use an inductor and make the current ramp up and down between a low/high mark. The end result is a roughly constant current that suits LEDs/chains well. – XTL Aug 13 '10 at 5:40
.. I expect those to be the most efficient thing. That leaves the problem of stepping down from mains. I doubt that extremely efficient total things exist ready-made if at all. – XTL Aug 13 '10 at 5:42
discard
