i use my lappy without battery.it means i remove the battery and laptop cable join the direct current supply.but laptop is working.can i know through this what happen to my laptop.is it good or bad to my laptop?THANKS.
closed as off topic by Leon Heller, stevenvh, tcrosley, AngryEE, Kellenjb Apr 5 '12 at 13:21
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
While this is not an electronic design question AS ASKED it has implications for designs using Lithium Ion (LiIon) batteries. As you know, turning off the power will immediately stop the laptop. BUT leaving the battery unused can be good for it compared to subjecting it to charge discharge cycles unnecessarily as long as it is stored in a "good" state. The best state to leave the battery in is when it has finished constant current charging and has just started constant voltage charging. This occurs in the 40 to 50 minute range when charging from fully discharged with most LiIon batteries. Storing fully charged is better than storing empty. |
