What is the reason of that 1 kilo ohm connected to the microphone? Why always too high resistors are used? I couldn't find any explanation. How do we calculate these values?
The microphone is an electret type, which needs a bias for the capacitor, which it basically is. Some electret microphones also have an amplifier built-in, which also needs power. The larger the resistor from \$V_{CC}\$ the larger the voltage drop caused by the supply current, though for an unamplified electret the current is low and the resistor may be bigger. |
The microphone as drawn in the circuit diagram is an electret microphone. It basically is a capacitor of which the plates can slightly move further and closer apart, by sound. A capacitor without an electric charge does nothing, so a slight electric charge is applied to the capacitor through the 1k resistor. Now when the plates of the capacitor start moving closer/further apart (caused by slightly changing air pressure from sounds), the capacity of the device changes with the distance between the plates and while the charge on its plates takes a relatively long time to change, the result is a varying voltage across the microphone. These devices have a very high impedance for audio frequencies and therefore you often see an small buffer amp built close to it, so it can drive a long cable. This type of microphone is very cheap and audio quality is high. |
Microphones can generate voltages by themselves sometimes, but often they need to be powered by an external source: in this case, the resistor is used to provide a supply to the microphone without forcing it's output voltage. The signal generated from the microphone will be a variable current which will cause a varying drop over the resistor. Note that there is a series capacitor to AC-couple the signal, which means removing the common mode voltage (DC component). And by the way, 1 kOhm is not a too big value: consider that 1 Ampère in electronics is often too big, and milliAmpères are far more common. |
