Tell me more ×
I have a wire to which I assign a complex right-hand-side expression with lots of bitwise operations. This right-hand-side expression is quickly becoming long and hard to maintain.
Is there a way I could replace the bitwise operations by if/else or case statements to help readability and maintability?
share|improve this question
Can't you just define intermediate wires? Then you can also give your intermediate signals intelligible names, further improving maintainability... – vicatcu Apr 10 '12 at 12:22
Also, many people avoid it in C-family programming languages, but to be proficient in Verilog you must become familiar with the ternary operator ?:. – The Photon Apr 10 '12 at 15:31
1 Answer
up vote 1 down vote accepted
Sure you can, just use the always @(*) construct (you need to make it a reg). You can handle inout ports easily too.
reg res;
assign inout_port = dir_out? res: 1'bz;
always @(*) begin
    if (x == 42 && y != z)
        res = 10;
    else
        res = y * 12;
end
share|improve this answer
The problem is that I cannot make it a reg because it is an inout port. – Randomblue Apr 10 '12 at 12:20
I've edited. Note that you shouldn't be using inout ports for internal connections anyway. – avakar Apr 10 '12 at 12:24
discard
