I have a system governed by the following relationship:
\$V_{OUT} = m * I_{IN} + 5\$
I need to write a transfer function for the equation. Would anyone please give me some suggestion of how to handle the constant term?
I have a system governed by the following relationship: \$V_{OUT} = m * I_{IN} + 5\$ I need to write a transfer function for the equation. Would anyone please give me some suggestion of how to handle the constant term? |
You can't. Your system is not a linear map. In general, a transfer function can only be derived from a system that's linear and time-invariant (LTI). The constant term violates this linearity. Specifically, the requirements for a linear map are: 1) \$y(x_1 + x_2)=y(x_1)+y(x_2)\$ (additive) 2) \$y(a x)=a y(x)\$ (homogeneous) If you plug-n-chug into both equations, the violation should be clear: \$y(x)=mx+5\$ 1) \$y(x_1)=mx_1+5\$, \$y(x_2)=mx_2+5\$, \$y(x_1)+y(x_2)=mx_1+mx_2+10\$ \$y(x_1+x_2)=m(x_1+x_2)+5=mx_1+mx_2+5 \neq y(x_1)+y(x_2)\$ 2) \$y(ax)=max+5\$ \$ay(x)=a(mx+5)=max+5a\neq y(ax)\$ |
