Tell me more ×
I'm using Altium Designer Winter 09 to synthesise a design for an FPGA. This includes a VHDL-defined entity MyShifter that includes generic parameters so I can have it be reuseable:
library IEEE;
use IEEE.Std_Logic_1164.all;
entity MyShifter is
generic
       data_width : positive;
       pad_width : positive
port
    -- ...other ports...
    DataIn        : in std_logic_vector(data_width-1 downto 0)
-- architecture follows...
With any other VHDL entity I could just right click on a schematic and use Place ยป Sheet Symbol, and then synchronise the sheet entries with the ports defined in VHDL. Altium will, later on, automatically generate the higher-level VHDL that maps ports to other ports and I don't have to worry about it.
When I try this with my entity-with-generics, I end up with sheet entry labelled DataIn[-1..0]. This is unsurprising, since I haven't "told" Altium what data_width actually is.
My question is: how do I tell Altium what the generic parameters data_width and pad_width are for a particular instance of MyShifter?
share|improve this question
I'm not sure a good solution exists. You could add a second VHDL file that instantiates your first VHDL file's entity with the appropriate generic map. Then you could just place that second-level VHDL file onto the schematic.
Not ideal, but it maintains reusability, as you can just make new second-level files for every different size you want, and you only have to change the first-level file to affect all instantiations.
share|improve this answer
Have you tried adding it as a parameter to the sheet symbol?
Double-click on the sheet symbol, Go to the parameters tab, and add a parameter data_width. I would guess you want it of type INTEGER.
I'm kinda guessing here. I don't really use Altium with logic synthesis.
Yes, my window theme is pink. You got a problem with that?
You may have to correct the sheet-entry labels manually after you add a parameter (or maybe just recompile the project).
Alternatively:
I know you can define project variables, but I don't know if they are presented to the VHDL synthesis system. If data_width is used in multiple places (and is the same everywhere), it may be worth trying.
Project >> Project Options >> "Parameters" tab.
It does not have the data-type options of the sheet-symbol, as described below, so it's possible that the VHDL synthesis system does not see project parameters.
Neither adding it as a parameter nor as a project parameter worked. Too bad :/ – detly Apr 11 '12 at 7:11
@detly - Well, then I'm out of ideas. – Connor Wolf Apr 11 '12 at 9:58
<Dr. Claw voice>AltiUUUUUUUUUUM!</voice> – detly Apr 11 '12 at 10:05
Maybe take a look at the Altium VHDL Synthesis Reference. Some of the error messages it describes deal with improperly declared constants. It may point you in a promising direction. (Ctrl+f and type "constant") – Connor Wolf Apr 11 '12 at 10:06
You may have to tie a minimal VHDL file into the schematic hierarchy at the highest-level, and define all your constants there. Then they should propagate everywhere (I think. I don't really know VHDL). – Connor Wolf Apr 11 '12 at 10:09
show 1 more comment
discard
