Tell me more ×
Is the Verilog real data type synthesisable for a generic Xilinx FPGA? If not, what alternatives do I have for real number manipulation in synthesisable Verilog?
share|improve this question
It depends on what tool you're using for synthesis... – Ben Voigt Apr 11 '12 at 14:55
@BenVoigt: I'm using ISE. – Randomblue Apr 11 '12 at 15:00
up vote 3 down vote accepted
Short answer: No.
Your best bet would be to build your own floating-point block. There are open-source examples. While you can make it IEEE754 compatible, there is no need to. It all depends on your application.
Some applications requires the range provided by single/double-precision IEEE754 numbers. However, other applications only require a small range that can be emulated with fixed-point numbers instead.
share|improve this answer
No, but some FPGAs have a core that works with built-in hardware for floating point. This Altera white paper discusses some details. However you would have to instantiate them; they can't be inferred by ISE or most other tools.
discard
