Tell me more ×
I would like to perform electromagnetic simulation and analysis of simple PCBs (coupling, capacitance, impedance, EMI, etc.)
Are there any reasonably priced (sub £1000), or free packages available which will do this?
share|improve this question
No, there are not any tools which are reasonably priced, much to my chagrin. Feko was suggested to me by my friend whom does EMC research for his graduate studies, he has had great results, but told me that it is still not easy to do. It takes him quite a bit of time to get even basic split ground plane simulations done. One of my good friends at NI uses some pretty fantastic software for simulating these things but they as a company, a decently large one, determined the cost of having more than one seat of a license not feasible. – Kortuk Apr 14 '12 at 19:19
Aw, this is sad. I mean, how hard can it be? – Rocketmagnet Apr 14 '12 at 19:21
yes, I have great interest in the area also. I have wanted to spend more time on it but have not had time recently. If I ever reach decent results with Feko I will shoot you a ping. There is software that will do some pretty advanced Design Rule Checks to help reduce issues with EMI. – Kortuk Apr 14 '12 at 19:22
Anyone interested in writing some simulation tools ? – Rocketmagnet Apr 14 '12 at 19:27
The reason it costs so much is because of the unbelievable amount of work that goes into an FEM or MoM solver for a PCB – Kortuk Apr 14 '12 at 19:31
show 6 more comments
up vote 4 down vote accepted
crunchyard.com offers cloud-based renting of CPU time which includes, as an option, Feko. You pay for VM/hour and the prices are quite reasonable.
You can download a free trial of Feko at their website which is unrestricted for 45 days (requires a login registration). There's also a free Lite version that you can use without time restrictions (you just need to ask for a license) but it has stringent limitations to simulation complexity. One thing you could do is use the Lite version to create/edit your model and then rent time at Crunchyard to run the simulation.
The Trial and Lite versions include good instructional videos for the basics of using Feko. But, as Kortuk said, it's laborious to recreate the PCB in it. One alternative you have is to import other CAD formats like DXF, provided your PCB design software supports it. But you're obviously importing just the geometry, not the EM profile of the traces. Those AFAIK you'll have to setup by hand. By reading Feko manual it appears that when importing Parasolid files it'll recognize special attributes of the objects that may contain EM characteristics, but I never tried it. You'd need a PCB software that can export that format and also be able to read those characteristics from somewhere (the schematics perhaps).
This is the simulation result for a simple PCB rectangular surface area.
share|improve this answer
Can you give us more info here about the product so that the link is not all we have. – Kortuk May 21 '12 at 6:19
Sorry @Kortuk, I was in a rush that day and never revisited it later. Hope it's better now. – fceconel May 22 '12 at 17:16
much better but I always ask for more. Any screenshots? – Kortuk May 23 '12 at 14:45
Check it out... – fceconel May 23 '12 at 22:45
If you Google "microstrip coupling calculator" and "microstrip impedance calculator" you may find a couple of tools for the passive calcs.
EMI is another matter. To determine the far field strength at 300 MHz from your board, what 300 MHz drive voltages and currents would you use in the simulation to represent to output from the 30 MHz processor on the board? Or whatever frequencies and harmonics are applicable for your board?
Because it is so difficult to come up with believable values for driving voltages and currents, often one uses: an existing body of design knowledge, best design practices, design iteration, and testing. This may be why folks are reluctant to develop a software simulator.
I can see that for serious applications, like developing consumer products etc, where you really need reliable quantitative results, this would be difficult. I would be happy with some simple simulations that would give me results good enough for qualitative learning. – Rocketmagnet Apr 14 '12 at 22:33
discard
