Tell me more ×
First of all, I can control Arduino from iPhone by using Processing and TouchOSC app.
But my task is to achieve a control wirelessly "without using a PC" in between. I need to control Arduino directly by iPhone via "wifi". I should only use an Arduino, a shield, an iPhone and the wifi network. This is the task i am given.
I am really confused which way to use and which shield to buy.
I would be so glad to have your opinions.
Regards,
share|improve this question
1 Answer
The WiFly Shield is basically a pcb with a Roving Networks WiFi module on it. You can configure it to set up an Access Point and connect your iPhone to the same AP.
I haven't used the WiFly Shield but I have used the Roving Networks WiFi modules and they are very flexible. They got a complete WiFi stack onboard and are pretty straightforward to use.
share|improve this answer
many thanks for the lead! i am a bit novice. i was using processing running on pc. but now i need a sketch/code to make wifly accept osc. i just need a simple sketch to upload to arduino. i need to turn on or off a led from iphone. any ideas about the code and configuration part? not so much clear explanation on net. – cmd1024 Apr 15 '12 at 14:23
discard
