I am setting up a audio delay circuit and i want to store the data on SRAM chip.
I am doing it with a 64khz clock and ideally i would like to write a word in every other pulse and read a word every other pulse so i'm reading and writing at 32khz - with a distance between the word addresses of course.
http://www.alliancememory.com/pdf/AS6C2016.pdf this is the link to the datasheet...
I was wondering if anyone knows a clever way to alternate addresses with 2 different 16 bit binary counters? or maybe there is an easier way in general to fulfill this task?
Also there isn't a clock pin on this chip which is confusing... do i just oscillate the "chip enable" pin?
