Tell me more ×
I was not sure if I should write it here or on Physics board, but I will give a try.
As I understood current (generally emf) can be generated in a system by varying magnetic flux.
For example, let's take AC generator. A loop of wire rotates between N and S magnets.
\$ \Phi = B \times A \times cos(\Omega)\$, where \$ cos(\Omega)\$ is the angle between the magnetic field B and normal of the loop A.
So the maximum flux can be achieved when the normal of the loop is parallel with magnetic field. But why emf at that moment is 0? And why emf is max when flux is 0?
illustration of problem
share|improve this question
If you stare at Maxwell's equations for a very long time it might get to you why this is the case. If it doesn't help, watch this and try again. – noah1989 Apr 16 '12 at 18:30
Please remember to use MathJax to make complex equations more easily readable! – Kevin Vermeer Apr 16 '12 at 18:33
Will do, sir. Thank you. – Arturs Apr 16 '12 at 18:35
up vote 2 down vote accepted
The rate of change of flux linkage is equal to the emf.
So it's your above equation should be differentiated with the subject of time. In that case you will get a sine equation. So that's the reason.
when you considering the flux linkage, Flux Linkage = << note the additional N there.
\$ B \times A \times N \times cos(\Omega)\$
if we took omega as angular velocity , then \$ \Omega \times t \$ is the angle relative to the starting position. So differentiate it in the subject of 't'.
In your sine train you could see clearly the rate of change of flux[gradient of flux]is max when angle is 90 deg. So that's the reason.
share|improve this answer
That was the missing piece! Thank you for the fast reply. – Arturs Apr 16 '12 at 18:34
Actually, that is incorrect. The maximum flux is the point where the magnetic field is flowing through the CENTER of the loop (i.e., pushing through the hole)
When talking about the normal of a loop we are talking about the normal of the surface (imaginary surface) area of the loop which points NORMAL the 2D plane of that surface area.
as for the EMF,
EMF = -d(flux)/dt
Where the Flux = BA*cos(w*t) (remember w = Omega) (w*t = theta...lets call it theta mod 360)
the emf = w*B*A*sin(w*t);
so when the Normal of the surface area and the magnetic field are parallel that means
theta = (w*t mod 360) = 0
sin(theta) = 0
and the Flux is at a maximum because
cos(theta) =  1 where theta = 0
From this you can see that the when the Flux is at a peak the abs(EMF) is at the smalest value. (I mention Absolute value because the signal shifts between positive and negative of equal magnitude)
Really good description. Thank you Adam. – Arturs Apr 16 '12 at 18:52
please note that EMF=-d(flux linkage)/dt not just flux. – sandun dhammika Apr 16 '12 at 18:58
flux/flux-linkage are kind of interchangeable (or are used interchangeably. In most classes, Flux Linkage isn't mentioned unless you study electric drives. The best way to describe it is the TOTAL area that the magnetic field is cutting. So if you have N wire wraps CUTTING the magnetic field your flux become N*B*A*Cos(theta) – CyberMen Apr 16 '12 at 19:10
That 90º lag comes from the derivative with respect to time in the Faraday's law of induction:
(Differential form)
(Integral form)
The left hand side of this last equation is the EMF. If those equations didn't have a derivate with respect to time, |EMF(t)| would be maximum when the apparent |B(t)| was maximum, but the (negative) derivative causes the sin(t) that there would be in EMF(t) to turn into a -cos(t), and that is where the 90º lag comes from.
discard
