There are a number of CAN modules built into microcontrollers these days. The PIC18F2480 is an example of that. Is that microcontroller (with built-in CAN) capable of driving a CAN bus on its own or is an external CAN transceiver/controller required?
I believe CAN has both a software and hardware layer and by the looks of it these CAN-enabled microcontrollers appear to have just the software, but it does not state that it can or cannot drive the CAN bus as is.
I'm looking to connect more than six microcontrollers through a CAN bus and would like to know if I need a transceiver across all of them or whether the built-in stuff can handle the communication from a software and hardware perspective.
Assume that I'll have necessary termination resistors and other small discrete components (caps, resistors, etc.)
