Tell me more ×
I am trying to figure out just exactly how this rotary switch works and what it's called (so that I can research it). There are usually 6-8 pads which are shorted to a common pad through fingers. That's easy enough... however, I don't believe these are acting as individual switches if that makes sense. I think they are multiplexed to one pin.
Rotary Switch
share|improve this question
Look up something called "focus", then learn to apply it. – Olin Lathrop Jun 4 '12 at 12:16
1 Answer
up vote 2 down vote accepted
X Pole by Y Way (with N detents) Rotary switch. THese are so custom, you wont find many like yours. ( if any ) But you need to know the state table for inputs connected to outputs for each position.
e.g. 1 pole 8 way rotary
share|improve this answer
Seems legit.... – Rocketmagnet Apr 24 '12 at 11:53
By the way( no pun intended ) there is too much solder on your "ways" and one is almost shorting out. Or just a bad photo... suck it up with solder sucker or gauze braid. – Tony Stewart Apr 25 '12 at 3:15
discard
