Tell me more ×
Disclaimer: I am a total newbie
I have something I bought that once is switched on does something each time I press a button, now, I want that to happen periodically(no accuracy needed) so I was thinking on substituting that button for something.
Is there any simple thing I could put there which would give me a periodic "button press"? Doesn't need to be accurate and I would be thinking on ranges from 5 secs to 30 secs, but anything is acceptable really, I would prefer non-ic alternatives.
Basically I want to swap something like this:
this
with a timed "push event"
share|improve this question
Can you be more specific about the thing ? – Rocketmagnet Apr 24 '12 at 19:02
You will need to give us a lot more details. Is this button NO or NC? What voltages are used on it, is there a pull up/down resistor? Why no ICs? I think you are still very much in the brainstorming stage and haven't done enough research on your own to create a good question. – Kellenjb Apr 24 '12 at 20:16
Kellenjb, I have no idea yet what the voltage is and not sure how to find NO/NC, I will try to extract that info from the device I have. – Arkaitz Jimenez Apr 24 '12 at 20:54
I vote for the mechanical approach: a motor geared down with a cam attached to the shaft that pushes your button every time it makes a full rotation. – Faken Apr 25 '12 at 1:12
up vote 2 down vote accepted
What's wrong with ICs now??
Anyway, what you want is a astable multivibrator, which is often made with an LM555 (IC!), but you can also make it with a pair of discrete transistors:
The period T = time the button is pressed (t1) + time between button presses (t2), where
t1 = 0.69 \$\times\$ C1 \$\times\$ R3, and
t2 = 0.69 \$\times\$ C2 \$\times\$ R2
Use the output to drive a reed relay via another transistor. Place contacts of the reed relay parallel to your button. If a contact resistance of a few tens of ohms is OK (the reed relay will be milli-ohms) you can use a 74HC4066 as the switch. But then we're again using an IC...
share|improve this answer
what did u use to draw that? looks cool – Arkaitz Jimenez Apr 25 '12 at 15:42
@ArkaitzJimenez: found it here. Excellent site, by the way. – Federico Russo Apr 25 '12 at 15:45
A microcontroller or FPGA could do this trivially. You would just need to put a loop counter and raise/lower the output at the desired times.
Or a whole PC :-) – Telaclavo Apr 24 '12 at 19:12
Or a servant :-( – Rocketmagnet Apr 24 '12 at 20:50
Why the down vote? He wants something automatic to simulate pressing a button and either of these could. – Brian Carlton Apr 24 '12 at 22:37
I didn't downvote. – Telaclavo Apr 24 '12 at 23:22
@Brian: I didn't downvote, though I don't think it's a good answer. You should give more details of how you solve this using a microcontroller. – Federico Russo Apr 25 '12 at 15:09
show 1 more comment
Sounds a little like a time delay relay. They come with lots of different options, but here's an example:
http://www.smarthome.com/7279/Delay-Timer-Relay-ELK-960/p.aspx
Can you give some more details in your answer? As it is now you are just recommending a consumer product where as you should be answering an actual electrical engineering question. That product is a circuit board and all, but it is specially designed to be used in smarthome applications which I consider to be consumer electronics – Kellenjb Apr 24 '12 at 20:10
Still needs a pushbutton, and only gives 1 pulse, not something periodical. – Federico Russo Apr 25 '12 at 14:47
discard
