Tell me more ×
I'm reading a book about data transmission inside a PC.
I'm trying to understand a phrase, translated from german, saying this :
In a PC, data are transmitted almost exclusively using the so-called 'neutral current method', which could be for instance NRZ or RZ.
I'm not sure if 'neutral current method' is correct, as I didn't find anything relevant with google.
Does anyone know what this method is ?
share|improve this question
NRZ = Non Return to Zero. That may help your Google'ing. It basically means that the signal on average is equally long high as it is low. I'm sure someone can further clarify better than I can. It is necessary to make the circuit reliably detect HIGH and LOW signals over long time. – jippie Apr 25 '12 at 7:48
@jippie: "on average is equally long high as it is low". That's only true if the number of 1 bits is equal to the number of 0 bits. For other coding methods, like Manchester, this is always true, regardless of the 1/0 ratio. – Federico Russo Apr 25 '12 at 8:23
Frankly, I don't see any relationship between "neutral current", a "PC", and "NRZ/RZ". I would say change the book :-) – Telaclavo Apr 25 '12 at 10:14
Googling "neutrale ströme" gets lots of links to pages about Bosons & Neutrinos. Possibly relevant to a PC fom the 23rd century :) – MikeJ-UK Apr 25 '12 at 10:56
I think the notion of "neutral current" is based on the fact that the voltage swings positive to negative around the ground reference (i.e. signal return path). In effect the current direction is different when the "signal" is high than when it is low. If the encoding is balanced (e.g. Manchester encoding), then on average the net average current flow is zero or "neutral."
share|improve this answer
This can be important if you have DC blocking caps at either end of the transmission line. If the average current is non-zero, charge will gradually build up on one of the DC blocking caps. Build up enough charge and you will let the "magic smoke" out. – ajs410 May 9 '12 at 21:35
I think its a bad translation.
"Neutral is used to indicate having no strongly marked or positive characteristics or feature."
In connection with RZ and NRZ baseband coding techniques, these are used in serial communication ports. The only thing remotely analogous to "neutral" for serial communication links are "balanced lines" which use differential voltages on controlled impedances to optimize signal quality over long distances. This applies to ethernet and RS485 & USB but not RS232.
..and thats my final answer for 1 million dollars
Balanced lines aren't always "current neutral" in the sense that the net current is zero (if that would be the meaning). In USB for instance both D+ and D- have positive voltages/currents. – stevenvh May 9 '12 at 7:53
if you put a current probe around differential pairs... the current is null. – Tony Stewart May 9 '12 at 8:05
Yes, but that's because a current probe doesn't see the DC component. – stevenvh May 9 '12 at 8:07
sorry steve .. hall sensor current probes work to dc and diff balanced lines add to zero current in both dc & ac – Tony Stewart May 9 '12 at 8:16
OK, I thought you were talking about a current transformer. But what you say isn't true. The Hall sensor (capital "H") will see a net current in both lines in the same direction: the voltage is positive for both (an AC signal superimposed to a DC level) and both lines are terminated to ground. – stevenvh May 9 '12 at 8:23
show 3 more comments
discard
