I am working on an audio circuit featuring the MOS Technology 6581 SID. The circuit works on a solderless breadboard with acceptable but still quite noticable noise. I am now going to design a PCB, but first I want to know what I could change in the circuit to further reduce noise. This is what I considered:
- Using more (differnt sized) decoupling capacitors
- Using a voltage regulator for VDD of the SID instead of taking it straight from the power supply
- Using a separate voltage regulator for VCC of the SID
- Using switching regulators instead of linear ones
- Using a better power supply
Schematics (click here for unscaled version)
Breadboard setup
