I am programming a motor controller where I have to specify the run current (coil peak current) and hold current (coil hold current) of the motors. The motor I used is a bipolar stepper motor, with a whopping 1.86Kg/cm of stall torque at 1.5Amp current (0.75A per winding) at 1.8 degree stepping angle.
However, the table in the specification makes me confused: It lists a different current for a different torque.
Here is a link to that motor controller.
How could I determine run current and hold current from this specification?
