Tell me more ×
I got 2 dc motors from a broken cheap RC helicopter. How can I Identify what type of motor it is? It has 3 terminals, but only 2 where used. It takes around 2-3 Amps of current at 3.5 V. Each trace in the board is connected to the adjacent one through a capacitor. Here are the pics: enter image description here
share|improve this question
Upload a picture. – jippie May 2 '12 at 10:48
To me the pictured motor looks line a pretty standard brushed motor. The capacitors are commonly used to reduce the noise coming out of the motor. One is connected from the + to body, the other from - to body and one to + and -. In helicopters I've seen they were soldered by hand, but since the market is expanding, it's not too strange to see them on a PCB integrated on the motor. – AndrejaKo May 3 '12 at 8:59
1 Answer
If only two were used and it moved then it must be a brushed motor. Brushed motors only use two terminals for the operation of the motor, brushless use four terminals I believe (three windings plus ground?). The third could be for some sort of feedback or maybe special grounding.
Edit: One caveat - there are some BLDC (Brushless DC) motors that have integrated controllers - these have two power lines and many control lines. Other BLDC motors have integrated commutation sensors (hall effect sensors) - these will have three wires to drive the motor and five for the commutation sensors (three signal plus two power).
Thanks to the picture I can clearly see - that's a basic brushed DC motor. The third connection isn't really a connection - it might be a structural connection (to help keep the PCB attached to the motor) or just grounding to chassis. Does anyone else have a better idea what exactly the third solder blob is used for?
share|improve this answer
The BLDC motors I know of aren't star-connected but delta-connected and therefore have 3 terminals. – AndreKR May 2 '12 at 13:20
I think I've seen a 'ground' connection on some. If I remember correctly it's not exactly ground, might be chassis or something. Regardless, if it moved with only two wires hooked up it must be brushed. – AngryEE May 2 '12 at 14:16
Brushless motor (Also known as Electrically Commutated Motors (ECM) are very similar to Induction motors. There should only be three wire terminals on it. (no need for ground, typically 2/3 windings are charged when in operation) – CyberMen May 3 '12 at 13:47
discard
