Tell me more ×
  __CONFIG(0, 0xFFFF);
  __CONFIG(1, FOSC_HS  );
  __CONFIG(2, BOREN_OFF);
  __CONFIG(3, WDTEN_OFF);
  __CONFIG(4, 0xFFFF);
  __CONFIG(5, 0xFFFF);
> __CONFIG(6, CP0_OFF && CP1_OFF);
> __CONFIG(7, CPB_OFF && CPD_OFF);
> __CONFIG(8, WRT0_OFF && WRT1_OFF);
> __CONFIG(9, WRTC_OFF && WRTB_OFF && WRTD_OFF);
> __CONFIG(10, EBTR0_OFF && EBTR1_OFF);
  __CONFIG(11, EBTRB_OFF);
The rows that I have marked cause a syntax error while building, others are fine.
C:\Users\Oppilas\AppData\Local\Temp\s6bc.:14: error: syntax error
I am using HI-TECH PICC-18 PRO v9.66, lite mode.
share|improve this question
Here's the sort of question you'd find in an IQ test: find one thing the problematic lines have in common. – Armandas May 6 '12 at 16:21
@Armandas I was going to answer read- or writeprotection :) – varesa May 6 '12 at 16:29
1 Answer
up vote 6 down vote accepted
OK, I thought I'll answer properly :)
The && is a logical operator and the result is boolean. This does not make any sense in this case. What you need is & (a bit-wise operator).
share|improve this answer
Oh wow, good one. This is one of those problems you can stare at for a whole day and never figure out. – AngryEE May 6 '12 at 23:27
@AngryEE I once typed |= instead of != in a condition. Now that took me a while to find. – Armandas May 7 '12 at 5:47
discard
