The problem is: I have a miniPCI card that I need to attach to a motherboard that only has an PCI-104 connector available for expansion. So i found an adapter that is a PC/104plus to MiniPCI adapter. My questions are:
- Is PC/104plus compatible with a PCI-104 connector? (I will not be attaching anything else to it). I read wikipedia article which is clear that you can put PC/104 on PC/104plus. It also says that all of PC/104 , PC/104plus and PCI-104 use PCI bus, but it is not clear if I can attach a PC/104plus to a PCI-connector.
- And if the above is yes, does it matter that is is not on a standalone stack with its own SBC but just a connector on a motherboard of an embedded PC?
EDIT: As many pointed I misread about PC/104 and it is NOT working with PCI bus, so please ignore it. But it does not change my question because the connector is PCI-104 and the expansion card is PC/104plus which does work with PCI.
