Does anyone know what the best way of getting from a variable input of either 110v or 220v and using just a standard breadboard (solder type) and getting down to a 5v output. Please let me know if I need to be more clear. This is fairly new to me.
The make line direct switched mode 5W power supplies. Best bet is used an old PC power supply. the white 4 pin Molex connects have readily avail outputs.
You don't say how much power you need. Anyway, the easiest way to a universal (85 - 265 V AC input) supply for PCB or breadboard mount is one of these:
It contains the same switcher as used in a wall-wart, but then for PCB mount. Compact (32 mm x 27 mm) and for 5 V output exists in a 2.75 W and a 4.5 W version. |
Any modern switched-mode Power supply will do the trick. They usually have an input range from 90 to 260 VAC and are available at pretty low prices. Also most consumer equipment contains something like this so it's worth trying to find any old CD/DVD player or a printer and take it from that. |
