Tell me more ×
I am trying to buy a stand-alone charger for my Archos 48 500Gb Internet media player. I think it uses a charger which is Output 5V 2A, but I recently came across a charger that says Output +5V 2A.
Is this the same as Output 5V 2A and would it work with the Archos without damage? What is the meaning of that '+'?
share|improve this question
Our site is for discussions related to the design of electronics and, I regret to inform you, not for consumer electronics support. – Kortuk May 12 '12 at 2:04
closed as off topic by Leon Heller, W5VO, Kellenjb, Kortuk May 12 '12 at 1:56
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
The + symbol refers to the output being positive. In practice, unless there as a - symbol in front of the voltage, you are almost always dealing with a positive voltage.
In this case, that charger will work fine with your device so long as it has the right connector for it.
share|improve this answer
Thanks Toby and Tony. Pls if it is regulated as you say how would that affect my player? and if not regulated how would it also affect it? – sam May 11 '12 at 23:17
Some DC bricks were not regulated so the Vdc was only at rated current and unloaded could be 6 or moreV This one may be regulated. The + implies it is DC not AC. thats all. Its redundant unless you wanted a jack changer with +/- It should work but not knowing if it is regulated or not is a concern.. Ask them..
Pls is it is regulated how would it affect my player? – sam May 11 '12 at 23:15
if it is not regulated there may be substantial AC hum. I cannot say for sure how excess voltage can affect your player. It may work, – Tony Stewart May 11 '12 at 23:20
