Tell me more ×
Is there a general form of transfer function (with peak frequency \$\omega_m\$ and quality factor \$Q\$) relevant for any type of bandpass filter ?
share|improve this question
a bandpass filter has two cutoff frequencies! – stevenvh May 14 '12 at 12:00
well I meant the peak frequency, the frequency at which the gain is maximum – snickers May 14 '12 at 12:02
Some bandpass filters have multiple peaks, like a Chebychev for example. – Olin Lathrop May 14 '12 at 12:04
@snickers - even without the multiple peaks (Olin's comment) the center frequency isn't enough to know the bandwidth. – stevenvh May 14 '12 at 12:06
@snickers - example of the frequency response of a Chebychev filter: cnx.org/content/m16895/latest/c92.png – stevenvh May 14 '12 at 12:09
show 1 more comment
1 Answer
up vote 2 down vote accepted
No. Whilst a standard second-order bandpass section can be defined in this way ...
\$H(s) = \dfrac{\dfrac{\omega_m}{Q}s}{s^2+\dfrac{\omega_m}{Q}s+\omega_m^2}\$
... it is also possible to have a second-order bandpass filter with the same characteristic frequency and Q but with a different transfer function. This previous question which addresses a filter with a stop-band attenuation of 1 is a case-in-point.
Furthermore, higher-order filters will require more than just these two parameters to define them since there are more coefficients.
share|improve this answer
discard
