Can you use the Arduino as an AVR programmer?
I use the mega-isp solution mentioned above - the Arduino avrisp sketch is here http://code.google.com/p/mega-isp/downloads/list I do not use the shield they have - I made up a simple cable using two 6 pin dual-in-line header sockets to fit the programming ISP connector on your Arduino. (I did not have two dil sockets so I used standard single in line and superglued two 3 pin sockets together. You then need a piece of ribbon cable or some wire. |
FYI: The mega-isp sketch is now included with the Arduino software as of version 0018 and no longer needs to be downloaded separately; it's located under File|Examples, named ArduinoISP. – esm Mar 3 '10 at 4:20 |
This solution works great too: Kimio Kosaka avrdude-serjtag method If you have assembled you own computers you may have spare case mounted USB cables/connectors that often come with new moherboards. Just wack off the USB end and you can use the motherboard connector as the ISP connector. A batch file like this can be used: (This is for the 328 chips, will set the fuses for high speed transfer and then upload the bootloader, and setting the lock bits when finished.
Yes, you can use the Arduino as a AVR programmer! Take a look at the mega-isp project. |
If you need hi-voltage programming (you have an otherwise dead chip) you can try this solution http://www.mightyohm.com/blog/2008/09/arduino-based-avr-high-voltage-programmer/ |
