Is it possible to use a common household 12 volt DC output adapter with this RFID transponder. I am a newbie but I am willing to learn. Here is a diagram of this RFID transponder system
of this.
http://i729.photobucket.com/albums/ww295/stealthmedal/6a2f9ff4.jpg
Wall wart:
The product description is as follows (for those in need of additional information) : The reciever operates on 12 VDC Details: The key fob is completely waterproof, and crunch resistant. Size:l.4" square and is meant to be attached to your keychain and has a recessed circle to allow you to place a custom label (if desired). The sensor is about 2.1" x 1.3" and is attached by 20" cable to the 4 1/8" x 2 1/8" receiver box. The sensor can be mounted in wood, behind glass or plastic and still function perfectly. The sophisticated receiver uses 6 ICs and have 12V OUT PUT WHEN TRRIGER . when the correct key fob is brought within 3 inches of the sensor. THE UNIT PUTS OUT 12V OUT PUT (MUST BE WIRED TO 12V REALAY), and when key removed from sensor relay will open.
Please help me.
