I am trying to correctly implement a circuit context for the e2v MiCS line of gas sensors (for example MiCS-5525). Reading the FAQ from the manufacturer they make this statement:
HOW STABLE IS A SEMICONDUCTOR GAS SENSOR WITH TIME?
Above a certain operating temperature, the heater resistance will slowly increase with time. This is a known phenomenon that can be easily compensated with an appropriate circuitry. Long-term tests have shown that at 40 mW, no drift is measurable over 6000 hours. At 80 mW, the heater resistance can rise up to 30%. By powering the sensor with an appropriate series resistance on the heater, this resistance does not impact the sensor power by more than 2% over the same period, which is sufficient for most applications. More sophisticated “constant power” circuitry can be used to fully eliminate this effect.
I don't understand why a series resistor for the heater is necessary or would help at all to combat the phenomenon in question. For the MiCS-5525 would it not be sound to simply apply 2.4V from a voltage regulator across the heater terminals of the device? I also don't know quite understand what they are talking about when they suggest a "constant power" circuit as an alternative, how would one go about designing such a thing?
