I'm wanting eventually to interface some memory to my fpga. This will require pins on the fpga that can both read data and write output to the ram.
I'm far away from doing any of that yet, but as a learning exercise wanted make a simple module in verilog that when a direction signal is '1' output a signal to a pin, and when it is '0' reads a value from that pin.
But I can't get anything to compile. I'm not completely inexperienced with verilog but feel I'm missing something fundamental here rather than just having a simple typo in my example.
This code doesn't compile, I'm looking for either how to make it work, or even just a pointer to what I'm fundamentally missing to make bidirectional signals work. If it matters I'm using xilinx tools and plan to synthesize this to an xc3s50 or similar.
// This doesn't compile...
module test(
input clock, // The standard clock
input direction, // Direction of io, 1 = set output, 0 = read input
input data_in, // Data to send out when direction is 1
output data_out, // Result of input pin when direction is 0
inout io_port // The i/o port to send data through
always @(posedge clock)
begin
// If direction is 1 then set
if (direction == 1)
begin
io_port <= data_out;
end
if (direction == 0)
begin
data_in <= io_port;
end
end
endmodule
edit The errors I get are -
ERROR:HDLCompilers:247 - "test.v" line 16 Reference to scalar wire 'io_port' is not a legal reg or variable lvalue
ERROR:HDLCompilers:106 - "test.v" line 16 Illegal left hand side of nonblocking assignment
ERROR:HDLCompilers:247 - "test.v" line 21 Reference to scalar wire 'data_in' is not a legal reg or variable lvalue
ERROR:HDLCompilers:106 - "test.v" line 21 Illegal left hand side of nonblocking assignment
