Tell me more ×
Looking for a low cost implementation to post ambient temperature readings from a sensor to servers via a COTS router.
1) Have a temperature sensor connected to a micro controller which sends data via a Wifi Module with a TCP/IP Stack to servers 2) Have a temperature sensor communicated via Zigbee to a coordinator that is plugged into a router and communicates with the servers.
Would like to keep the cost of the solution below $20. Another constraint is the battery life. Wifi modules with TCP/IP consume more power and cost more.
What particular devices/chips/microcontrollers would you recommend to solve my data communication problem and fit within my budget?
share|improve this question
very close to this question I asked here – Matt Anderson Jun 5 '12 at 21:47
Elaborate more on the power requirements. Is this device unable to be powered by a wall-wart, etc? Since it's wireless, how far away will the device be placed from the router? Is it going to be outdoors or indoors? – Toby Lawrence Jun 5 '12 at 22:22
I wrote up a blog entry on getting from an analog sensor to the internet (Pachube) via Ethernet (with a Nanode) over an inexpensive, low power RF link (Wicked Node / Receiver Shield) a while ago: blog.wickeddevice.com/?p=244... but under $20 is a tall order. – vicatcu Jun 6 '12 at 1:40
I would use a Digi Xbee on the sensor to pass the information to a Connectport X2, which has either ethernet or wifi. The Xbee is a Zigbee radio with a simple serial interface. The X2 has a Zigbee radio and an IP connection and runs python.
There are several tutorials on how to get one working. This one looks like a good place to start.
share|improve this answer
Pachube, which is now called Cosm, is a service/platform/API for posting sensor data to the web. If you click on Support/API and then go to hardware, they have a lot of information on the various hardware that is compatible with their service. And they have libraries for controllers like the Arduino.
https://cosm.com/?pachube_redirect=true
If you're not in a hurry, you can wait for the new Electric Imp kits. The developer kits should be coming out soon. (Says "end of June, 2012" on the website).
http://www.electricimp.com/developers/devkits.php
The Hannah: The hobbyist board even has the temperature sensor built in.
discard
