Does anyone know what the technology in the "turn any surface in to a speaker" speakers is called?
It is all propriety, patent protected stuff and you just use pre made modules or is it possible to build it up from raw components?
There's not any special name for it that I know of. Vibration Speaker/Vibration Transducer/Surface Transducer. These names are all used interchangeably. It's simply the voice coil of a speaker with a mechanism to attach to a flat surface rather than having a cone attached. Here is an article on the technology which is pretty much the same as speaker technology has always been: http://electronics.howstuffworks.com/gadgets/audio-music/vibration-speakers.htm And here is the transducer itself without as much plastic housing and markup: http://www.parts-express.com/pe/showdetl.cfm?PartNumber=300-375 You could build it up from really raw components though. Magnet + voice coil + method to attach to surface. I used to work in a speaker repair shop. During the reconing process, we would sometimes run the voice coil with the cone removed by hooking up a frequency generator to check for damage to the coil. A big enough speaker supplied with enough power would vibrate the bench. If the speaker had been attached securely, it would have the same effect as a Vibration Speaker. |
Sparkfun sells what they call surface transducers, which seems like an accurate and appropriate name: they change electrical energy into energy on a surface. There's a video teardown here, one frame of which shows the basic construction:
There's a voice coil with a few spring arms, a heavy housing containing a magnet on the table, and an adhesive plate to the left. Nothing proprietary or patented but to build a good one takes a good deal of difficult micromachining. As mentioned in the comments there:
Elsewhere in the thread they are called 'surface exciters', but this seems to refer to a lower-power, cheaper variety. |
I once happened to hear about a company called EMO LABS. The website says they're in the process of changing their name to "Edge Motion Technology". Maybe this is because they want their speakers to be used for hip hop, punk, kraut, techno and free jazz as well - and not have the use limited to emo rock. It seems they have a patented product called Edge Motion™. Relevant patents might include, but are likely not limited to:
More information may be found if you put the words "emo labs invisible speakers" into a search engine. Disclaimer: I'm really not affiliated with them, but their CEO used to live in the same 'hood as I do before he went to Boston, so these are just some random pieces I think I know. |
